GSR in my EK not responding correctly
I was hoping someone can help...when i try to step on the car pretty good it just doesnt pick up its like it wants to but cant u could even hear the V-tec kick in but just not going anywhere. if someone has any info please share.
If you loved me, you'd all sell me your magic cards to me today
Re: GSR in my EK not responding correctly
cELs, ECU, which harness did you use, obd1 what?
Can't help you unless you work with us.
PHANTOM MENACE
No worries, do you know when the last time it had a tune up was? And if so, what was replaced?
Are you familiar with ignition timing and mechanical timing?
Do you know how to remove the spark plugs?
I'm asking because these are the easiest things to check without necessarily being a car guy (sorta). Also, without any check engine light (CEL) codes we are really guessing at what might have happened. Do you recall anything significant happening before you noticed the condition developed?
The ECU should be located in the passenger side foot area just behind the door, can you look and see if you can find the label on the ECU itself? It will be able to tell us what ECU you have.
PHANTOM MENACE
Hah you asked about the check engine light earlier. Well at least now we're onto something.
To the original poster (OP): If you ever get a check engine light that's your ECU trying to tell you something is wrong.
cel= Check Engine Light
you seem a little lost about your car so take it to a mechanic, cause if you think a tune up is an oil change then the faq is just going to hurt your brain.
want2drive
06-14-2011 10:11 AM
