GSR/ITR oil cooler?
Re: GSR/ITR oil cooler? (Hard2Find)
It is on the block, its sandwhiched between the oil filter and the block. Water flows through it and cools the oil before/after filtration. No pics, but all GSRs should have it, but ALL B16s should. Before I added my cooler (front mount), my oil temps would peg 250 on the highway on trips. now, nothing over 200 or so.
New User
oh, so its not like a frount mount oil cooler?
thanks
thanks
New User
Re: GSR/ITR oil cooler? (acura_typer)
Not all do. My 94 B16A does not, and i know for a fact 99-00 VTEC does not.
That's weird considering the b16s will rev up higher than the 1.8L
what needs to be done to make this work with a block that doesnt have an oil cooler? i see two lines coming out of the oil cooler, where do those go?
Re: GSR/ITR oil cooler? (Jackson)
You need a GSR/ITR water pipe, and the two rubber hoses/clamps, the cooler, and the fitting that bolts to the block/filter screws to.
Its a worthwhile swap if you have the motor out, it'll save your oil.
thanks, i think i have all those parts laying around from a 1st gen b16 that came with it. ironic how that the 1st gen has it and the b16a2 doesnt.
