gsr front rotors on civic?
Old 08-03-2002, 04:33 PM
jdm97civic's Avatar
Default gsr front rotors on civic?
alot of people have been telling me that I can put gsr front rotors on my dx civic coupe, is this true? Will this really affect my stopping power and do I have to make any mods?
jdm97civic is offline
Old 08-03-2002, 04:35 PM
DragII's Avatar
Default Re: gsr front rotors on civic? (jdm97civic)
yes, it is infact true. but EX rotors are the same size as GSR....however...GSR has bigger calipers.
DragII is offline
Old 08-03-2002, 04:47 PM
jdm97civic's Avatar
Default Re: gsr front rotors on civic? (DragII-Sellout)
would I be able to put GSR calipers on my civic too?
dogpile5's Avatar
true, i agree. that's what i did. cheaper than a 5lug conversion
dogpile5 is offline
Old 08-03-2002, 09:01 PM
D Tranny Guru
Mista Bone's Avatar
if you put the Teg knuckles on also, yes.
Just get a Teg front brake swap (knuckles to calipers) and install on your DX.
Best $150 you'll ever spend!
Mista Bone is offline
Old 08-03-2002, 09:29 PM
civic23g's Avatar
Default Re: gsr front rotors on civic? (Mista Bone)
I put them on the front of my 96 civic dx and it helped stopping power quite a bit, the pedal felt a lot better too. All u need are the knuckles,calipers,discs, the stock brake lines will fit, mine did. Definatly a good,cheap upgrade.
civic23g is offline
Old 08-04-2002, 09:21 AM
Default Re: gsr front rotors on civic? (civic23g)
I just did the whole GSR brake swap. You should get rear disc brake too. The GSR front calipers are better so I would suggest doing the whole knuckle/caliper assembly. If you do this swap do the 1" master cylinder/booster and proportioning valve.
Takeoff is offline
Old 08-04-2002, 04:54 PM
Dr. EKology's Avatar
Default Re: gsr front rotors on civic? (C5_ALLMOTOR)
so what brakes parts from a GSR would fit on my 97 ek (front and back)?? im planning on getting a set of 94 GSR rims so im sure they'll clear the calipers.
Dr. EKology is offline
Old 08-04-2002, 05:27 PM
HotHB's Avatar
Default Re: gsr front rotors on civic? (EKology)
my 14 inch HX wheels clear my complete GSR brake setup, front and back, even tho its real close in the front.
HotHB is offline
Old 08-04-2002, 07:41 PM
D Tranny Guru
Mista Bone's Avatar
How much you wanna bet?
VERY commom swap. YOur using complete Teg parts, WHY would it not fit?
Rememeber I said you must use the Teg knuckles also.
Simple unbolt/bolt-on swap.
Old 08-04-2002, 07:46 PM
poison's Avatar
Default Re: gsr front rotors on civic? (HotHB)
umm, spacers/washers?
i had 14" hx rims on my front and didn't clear (and I have an ex)
poison is offline
Old 08-04-2002, 10:09 PM
If you plan on getting the rims do the whole swap. It will fit fine w/ the wheels you are going to buy. Everything should bolt right up. Make sure you get an alignment right away. My alignment was so far off on the front, I was drifting while driving straight.
Takeoff is offline
Old 08-04-2002, 10:11 PM
dom93hatch's Avatar
Tell us how you did this.
dom93hatch is offline
Old 08-04-2002, 11:18 PM
DOHCtorTHRUST's Avatar
Default Re: gsr front rotors on civic? (dom93hatch)
i've been tailgating so much ever since my gsr knuckles were installed, this mess stops hella fast compared to the stock cx, when i tested my friends car(cx w b18c1) i could stop after redlining 2nd.... that tells you the differents... this **** ROCKS!!!!!
[Modified by DOHCtorTHRUST, 6:57 PM 8/5/2002]
DOHCtorTHRUST is offline
Old 08-04-2002, 11:26 PM
poison's Avatar
yes, w/o shaving off part of the rim or caliper
poison is offline
Old 08-05-2002, 03:29 AM
gavhowe's Avatar
Default Re: gsr front rotors on civic? (poison)
Will prelude 2.2 calipers fit a d16z6 civic i have abs so have 10.3 rotors
gavhowe is offline
Old 08-05-2002, 07:35 AM
AmauryR's Avatar
yep, just finished them on my '93 Si - best upgrade for the money (brake-wise).
felt a LOT better than my old slotted + ceramic pads vs the gsr rotors + nearly-dead stock pads (which I was suprised). I believe '94+ civics w/ abs or 4wd (ex/si) had the larger 10.4" rotors (same as gsr), so the dx/cx/lx's had the 9.5" rotor. anyways - swap the whole knuckle/rotor/caliper + reuse the civic brake line that goes onto the caliper. hope that helped some.
-l8r
AmauryR is offline
Old 08-05-2002, 07:43 AM
dom93hatch's Avatar
Default Re: gsr front rotors on civic? (Death Scythe)
I think the Teg front brakes would be enough for a street car. IMO rear discs on a street Honda are for for aesthetic appeal than anything else. If you're going to take it to the track, might as well get all 4 corners done.
* Still awaiting the response of the dood who got GSR brakes to clear HX wheels
Old 08-05-2002, 09:19 AM
poison's Avatar
poison is offline
  • Ask a Question
Question Title:
Description:
