gsr ecu ? for del sol
hey
i am getting a gsr swap for my del sol and i have a single over head cam vtec right now with the p28 in it and i was wondering if i should keep that ecu or use the one that is gonna come with it
thanks
thanks
Re: gsr ecu ? for del sol (nighttrain33)
it really depends on what you want to do with your car in the future.
I say keep the P72 for your swap and keep the p28 off to the side. later, you can use the P28 to chip and tune your engine if you decide to build it.
Re: gsr ecu ? for del sol (del-sol-95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del-sol-95 »</TD></TR><TR><TD CLASS="quote">when does vtec and rev limiter kick on for both of these</TD></TR></TABLE>
<U>P28</U>
VTEC: 4,900 rpm
Rev limit: 7,200 rpm
<U>P72</U>
VTEC: 4,400
Secondaries: 5,700
Rev limit: 8,100 rpm (fuel cut off: 8,200 rpm)
<U>P28</U>
VTEC: 4,900 rpm
<U>P72</U>
VTEC: 4,400
Secondaries: 5,700
TSPeed Factory
Re: gsr ecu ? for del sol (ADVAN EG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ADVAN EG2 »</TD></TR><TR><TD CLASS="quote">it really depends on what you want to do with your car in the future.
I say keep the P72 for your swap and keep the p28 off to the side. later, you can use the P28 to chip and tune your engine if you decide to build it.</TD></TR></TABLE>
agreed! the p72 will help if you plan on running the stock gsr intake manifold for a while.
Re: gsr ecu ? for del sol (AzntaggeR)
it doesnt matter what the p28 vtec/rev is at
you wont be able to use it without chipping it with a dohc map base
TSPeed Factory
Re: gsr ecu ? for del sol (DutchEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchEG6 »</TD></TR><TR><TD CLASS="quote">the GSR p72 is obd2 </TD></TR></TABLE>
no, not all of them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchEG6 »</TD></TR><TR><TD CLASS="quote">hmm oke...
i have here a p72 obd2 gsr ecu... but i stick to my p30 </TD></TR></TABLE>
When I first got my swap, the idiots gave me a P72. It must have been OBD1 since we had to do the OBD2-OBD1 conversion .
-Shane
-Shane
i got a del sol with a gs-r swap too......
if u gonna keep the stock gsr manifold keep the p72......i hate dual stage vtec by the way
i say get a skunk2 intake manifold........p28....and tune it and ****
cascanjepp
11-21-2012 06:50 PM
Boostedtracksol
04-19-2006 09:49 PM
UNDER PRESSURE
35
07-29-2004 07:32 AM
