GSR dash in my eg hatch
I'm buying a gsr dash for $100 WITH the guage cluster and everything. I was wondering about the gauge cluster... does it just plug in? will the speedomoter still work right? I did a search, but came up with nothing. thanks
Re: GSR dash in my eg hatch (ImportHatch)
No it isn't all just plug in either. The guage cluster will not work. You can make it work but you have to rewire it. I know first hand because i just did my own swap in my 92 SI. Ask me for more details.
Re: GSR dash in my eg hatch (redteggy)
https://honda-tech.com/zerothread?id=94431
[Modified by spankaveli, 11:46 PM 3/3/2002]
**FROM LINKED THREAD**
You don't have to rewire anything. It all plugs right in. One plug you'll have to cut the sides out of to fit and add three wires. Look at my other post for what you need.
its really easy, as far as repinning the gray plug, piece of cake, all u need is a little common sense. yes, reusing the civics hazard plug is extremely ghetto. i got the civic plug in my car now, only because i dont have the integra one yet. it doesnt quite fit right in the car, but looks a hell of alot better than the civic dash. its a simple swap if u have half a brain. should only take a couple hrs for the dash, the wiring is easy too, but figuring out locations is a bit harder for repinning. should take no more than 4 hrs for all.
Re: GSR dash in my eg hatch (JFK.com)
Good lord, you have to get all that stuff from the GSR just to make it work right?? for the dash i mean. Maybe i'm better off just getting the gauge cluster. btw, this is importhatch from earlier, i was on his comp.
Re: GSR dash in my eg hatch (VXpride)
mines in my race car so i didnt get all that mumbo jumbo crap the other guys r suggesting. when i actually do need heat outta the car, the only place i need it at is on the front windshield and guess what??? it still blows on the windshield.
here you go.. i did not want to do the whole dash cause the door panels do not fit correctly so i just put the guage cluster into my civic dash.. im fine w/ it for now and if i ever do decide to do the whole integra dash i have already rewired the whole cluster wiring so everything else should be cake..
i have made a great wiring diagram of the wires taht need to be either cut and soldered back in or repined, if you want the diagram let me know..
[Modified by 95CivicEX, 1:56 AM 3/4/2002]
Hey 95civicex can you send me the diagram? My e-mail is GRUMPY_ASSS@hotmail.com thanks. Also what wiring harness are you using?
Re: GSR dash in my eg hatch (Extreme_Hybrid_Hatch)
Re: GSR dash in my eg hatch (95CivicEX)
hey 95CivicEX can you send me that diagram also my e-mail is Project SOHC EX@aol.com. Thanks.
Sincerely,
Project SOHC EX
Sincerely,
Project SOHC EX
if you could email me that diagram too I would appreciate it, and also what you had to do to get the cluster to fit into where the old civic cluster was. email is darksubrosa@aol.com thanks
Re: GSR dash in my eg hatch (DOHC93DxCoupe)
Sign me up for one of those diagrams to please. celicaturbo87@hotmail.com
i will try to get the wiring diagram sent out via email tonight after work and if i dont get it emailed to everyone (on accident or mistake) i will also post it on the thread..
I say charge everybody $50 for the diagram except Extreme Hatch Hybrid.
ill try to get the diagram email and posted later tonight, just got home from work and need to clean up the crib.. later fellas
iight sorry everyone i forgot to post the diagram last night, got to late and i fell asleep.. i dont have the exact diagram cause i have deleted the file or lost it on the hard drive but i do have the next best thing, a list of all the wires that are on the eg and dc cluster wiring harnesses..
a few questions to be answered that i have received by email sorry i cant write back to everyone that emailed me.. you will need the harnesses from the back of the integra cluster, the harnesses from an eg civic do NOT fit.. what many people have heard is that the harnesses from an EK civic fit but need tob e trimed or something to work, ive never done an EK cluster swap and have no experiance w/ that year car at all.. so get the harnesses from the local acura dealership or the junkyard..
you will need to do a little triming of the black trim that surronds the cluster in the civic dash, the integra cluster does not fit perfectly.. a dremel and some paitience is all it takes.. this whole project can be done in less than 2 hours if you have experiance w/ electrical things.. you will need wire cutters, electrical tape, soldier (if you soldier the wires) or heatshrink to protect the wires from shorting out..
iight here is the list of all the wires.. just follow it closely and its not tough, there might be a few wires left that dont plug in anywhere but trust me it all works cause ive done it, and some of the wires are the exact same color so that makes it even more easier... good luck, ask me questions if you need either by email, IM, or AIM..
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
5. wht/blu charge
8. blu tach signal
10. blk/yel power
11. red/blk power
12. red power
6. blk ground
8. yel hot
9. grn trunk switch
passenger side airbag cover
I called acura and they said they only sell it with the airbag and its a grip. Im buying a dash to put in my 92 cx hatch and dont need the actual airbag, just the cover. Anyone have any ideas on what to do.
Re: passenger side airbag cover (Turbolude)
i have the dash minus the airbag that i have been trying to sell..
if you can arrange shipping and all ill let you have it for $70
dash, wiring harness (gotta have this), gauge frame bezel, *****, climate conrol, buttons
(missing cluster, lower console, and center console)
email or pm me
email or pm me
Horseofcourse
06-18-2007 10:16 AM
