GSR cluster??
Re: GSR cluster?? (THC07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC07 »</TD></TR><TR><TD CLASS="quote">Use it
https://honda-tech.com/zerothread/642479</TD></TR></TABLE>
it only says GSR into eg is there a difference between an eg dash and an ek dash because i wanna swap the cluster into an ek?
Re: GSR cluster?? (jewpont)
you would most likely have to modify cluster for it to fit in an ek. you may be able to use the guage faces on your stock cluster with little modification.
Ek Forever y0!
Re: (jewpont)
GSr cluster looks great. You'll need some pipe strapping and some patience.
It's hrd to make it look right, there will always be a perfect bezel fitment issue, but if that doesn't bother you like it would me, then go ahead.
There's a write-up in the sticky at the top.
https://honda-tech.com/zerothread?id=407737
It's for an ITR cluster but physically they're the same.
