GSR brakes+ 2000 sir sway bars?
My 2000 civic hb has a 98 gsr brake swap on the front and rear. I was wondering if anyone knew if 2000 civic sir stock swaybars ( front and rear) would work with my setup, thanks.
Re: GSR brakes+ 2000 sir sway bars? (RajaNiche)
i am currently using GSR front and rear brake setup, i am still using my stock DX rear trailing arm...and as for the front i have 99-00 Si LCA and 99-00 Si front sway bar (26mm) https://honda-tech.com/forums/images...es/emsmile.gif and of course DX upper a-arm and GSR knuckle
So i would need 99-00 si lca front and rear to make the sway bars work?
you'll need si(r) front lca's for an si(r) front sway to work. the stock rear lca's are fine, you just need the bracket that bolts to the subframe.
