GSR.....bad VSS or something else?
Ok recently I got a gsr engine.etc.... I found out the vss was bad ( had a broken pin). So I got my hands on one from a JDM tranny b16. I put it on reset the ecu and bam **** still came back on. Same code 17. So my question is now what could be wrong? Is there anything else I can look for now that the VSS itself is out of the way? Any input is greatly appreciated.
Re: GSR.....bad VSS or something else? (mortificationrock)
Broken wire, backed out pin, poor pin tension. See if the VSS has 12v, 5v, and a good ground. If its missing any one of those, it'll trip the CEL immediately.
Re: GSR.....bad VSS or something else? (King V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King V »</TD></TR><TR><TD CLASS="quote">Broken wire, backed out pin, poor pin tension. See if the VSS has 12v, 5v, and a good ground. If its missing any one of those, it'll trip the CEL immediately.</TD></TR></TABLE>
Well the plug looks normal. So I really wouldn't know if its a broken wire. All I know is that my speedometer don't work for nothing. And how do I go about checking the 12v,5v, and ground. Sorry im a noob to B series. This is my first B series engine.
Ok can anyone confirm some things for me please..
#1 my ecu reads 37820-P72-A02-970-105029. Is this the correct ecu for a OBD2a engine. Car is 96 so I guess its obd2a.
#2 I could have swore that my 97 ej8 had 3 plugs in back of the cluster.(memory could be wrong) This Si cluster only has 2 plugs. And so does the harness itself. WTF?
Please help me clarify this. Thanx in advance HT
Bump. Need some help....first b engine and I think who ever did this did it wrong.
Note: Also tested the VSS plug and I got the following readings. On one wire(middle I believe) I got 4.7v and on the other I got 11.7-11.8v. When tested I used the ground of the plug also so im guessing ground is good also.
Modified by mortificationrock at 8:18 AM 9/9/2008
Man I can't believe no one has been able to help me. I've searched and found nothing.
Where is NOFX when you need her. Or anyone of the other guys?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mortificationrock »</TD></TR><TR><TD CLASS="quote">
That looks about normal. Sounds like you may have a beef with compatibility of harnesses between the cars or a broken/missing wire that feeds the ECU the signal from the VSS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King V »</TD></TR><TR><TD CLASS="quote">That looks about normal. Sounds like you may have a beef with compatibility of harnesses between the cars or a broken/missing wire that feeds the ECU the signal from the VSS. </TD></TR></TABLE>
Now by any chance would you know the color of the wire for the VSS? Could it be the ecu? Cuz my speedometer still don't work and I wonder why?
bump for this guy. had issues with my VSS. turned out that i did a crappy job splicing the wires haha. and no VSS = NO VTEC
