grrr... car wont go into gear!
hey poeple,
been lurking around this forum for sometime, read alot... dont say much... i need your help now. i have a delsol with a b16a motor, for a couple of days now it is having some clutch/gearing problems. i goto pump the clutch and put it into gear, it will hasitate to go in and now it does not go in any gear at all. when it does go into a gear , it will get stuck in that gear when i try to shift to another gear and bog down the motor. i checked the clutch resovior and it is full. master clutch and slave cylinder works becuase i bleed the slave and lots fluid comes out. there alot of gearing/grinding noise coming from the tranny. so i changed out the tranny fluid with syn oil, still the problem exist. i am thinking its the bearing, but have no idea on how to replace that. let me know what you guys think.... |
Re: grrr... car wont go into gear! (solRNY)
could it be the syncros?
how old is the clutch? can you changing gears with engine off? how is your clutch pedal feel? look inside the car and check to see if you master clutch cyclinder is leaking or not? put your foot one the clutch pedal with the engine running (neutral) can you feel the throwout bearing vibration? could have a bad throwout bearing. what happen when you put it 1st gear and let the car roll off do you hear bearings noise? it could be your input bearing going bad.
Re: grrr... car wont go into gear! (2lua)
Is that slave cylinder stock? Almost sounds like a slave cylinder is trying to take a crap on you.
