ground control coilovers compatibility questions
friend has GC coilovers just lying around and I would like to buy them off of him
The coilover are from a 91 Civic
I need them for a 97 Civic
Another issure may be that the sleeves are for shocks like tokico/kyb/ stock
And I need them to go on koni yellows, I know there are koni specific sleeves
Any reason why they wouldn't fit on knoi yellows if I use the spring perch instead of using the just clip on the shock?
jus f0 dekarayshunZ
Re: ground control coilovers compatibility questions (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">friend has GC coilovers just lying around and I would like to buy them off of him
Any reason why they wouldn't fit on knoi yellows if I use the spring perch instead of using the just clip on the shock?</TD></TR></TABLE> i think the spring rates are different for that year...if im not mistaken usually civic springs are interchangeable 92-00..someone correct me if im wrong
Re: ground control coilovers compatibility questions (ciRcuitSi y0!)
the 6th gen is heavier than the 5th isnt it? wouldnt that make for a little change in spring rates? or is the difference in weight negligable?
