grinding noise when going into 3rd
hey guys i have a 00 si with 608xx miles on it. sometime when i take it up to 6k or higher and shift into 3rd gear it will make a grinding noise it doesnt happen in any other gear. it has a act clutch with a street disc.. any help would be great thanks in advance.
Personally, I think that labor would charge a grip for it. Then again, if you have a cousin who knows how to do it...it would probably save u a ton...this is of course if he "knows" how to do it.
Re: (sohc_coupe24)
yeah he knows how to do it he has his own shop but well see i talked to him he told me to bring it down tomorrow and he will take a look at it
Re: (toggs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toggs »</TD></TR><TR><TD CLASS="quote">well if he is gonna tear it down and "look at it" then you might as well put in new ones. personally i would drive that tranny into the ground </TD></TR></TABLE>
Re: (USDMej1)
hes not really going to "look at it" probably just drive it and if i have enough money hopefully this weekend get it fixed. i would "drive it into the groung" but i dont have the money for a new tranny though a tryp r with lsd would be nice
Re: grinding noise when going into 3rd (00 Em1 Si)
Definately Syncroz suppppper common wit hondas
i say for the $ u spend on replacing them.. unless its just 3rd n forth ( they usually come in a set ) u might as well buy a used tranny
i got the exact same clutch/flywheel in a GSR tranny and get the same thing only goin to third gear...
ive been told try synchromesh fluid first, the GM brand was recomended as the best by someone i know whos tried diff kinds.
unfourtunatley i havent tried it yet so i cant give you a definite thumbs up on it, but i plan on pickin up some... deff worth a try before tearin down a transmission
Re: (EGsrHATCH)
thats wierd maybe ill try that synchromesh before we do anything deff dont fell like tearing it apart. maybe tomorrow ill go pick some up ill let you know if it works. thanks
Re: (00 Em1 Si)
same thing happened to me **** started grinding on top of third and then replaced the fluid with GM syncromesh and it doesn't happen anymore but if it still does then you need new syncro's or just replace tranny
Re: (di2Ferio)
where should i look to get the synchromesh at? maybe like summit racing, im only aobut 30 min from there or would like advanced auto have it?
Re: (00 Em1 Si)
advance auto used to have it when i worked there a couple years back. i don't remember the exact price, but it wasn't much. Last time i saw it they had moved it over with the transmission rebuild kits and b&m shifter fluid, so it may not be with the normal tranny fluid.
Go Tigers!
Re: (00 Em1 Si)
synchromesh = waste of time
you need #3 and #7
#3 = 23440-P21-000 GEAR, MAINSHAFT THIRD $123.73
#7 = 23623-P21-315 SLEEVE SET, SYNCHRONIZER (3-4) $162.83
Once trans is off of car:
90min job if you know what you're doing
180min job if you're a virgin
2 week job if you're like most dolts on here
you need #3 and #7
Re: (jagolas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jagolas »</TD></TR><TR><TD CLASS="quote">advance auto used to have it when i worked there a couple years back. i don't remember the exact price, but it wasn't much. Last time i saw it they had moved it over with the transmission rebuild kits and b&m shifter fluid, so it may not be with the normal tranny fluid. </TD></TR></TABLE> thanks
Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">synchromesh = waste of time
you need #3 and #7
2 week job if you're like most dolts on here</TD></TR></TABLE>
why do you say its a waste of time? you dont think that i should try synchromesh to try to hold me over until i save up enough money to get maybe a type r with lsd. eventually when i sell my bike im going to go boost idk what to do. like i said my cousin can do it but i dont know if i want to wasnt the time/ money if its just going to be replaced.
you need #3 and #7
its hardley a waste of time to try something that could work and is pretty inexpensive...
and as far as where to get it, i would assume GM dealership serviceshops keep it in stock
Go Tigers!
Re: (EGsrHATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGsrHATCH »</TD></TR><TR><TD CLASS="quote">
its hardley a waste of time to try something that could work and is pretty inexpensive...</TD></TR></TABLE>
That's the thing. It doesn't work. yeah, you could buy an ITR trans, but who's to say that it won't grind in 1 month?
Try selling your b16 trans w/ a 3rd gear grind. you won't get much for it.
Or you could get a used ITR LSD and replace your damaged parts for less money.
