grinding into 3rd gear
ok so when im racing or watever i grind into 3rd gear........it only does it at high rpms.........now do u think it could be because of low tranny fluid or could my gears just be messed up?
Re: grinding into 3rd gear (Lookinaround)
b series trannies grinds in 3rd a lot. if you beat on it, dont expect it to last like 200k. gst some syncromesh and it will make it go away
Re: grinding into 3rd gear (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">b series trannies grinds in 3rd a lot. if you beat on it, dont expect it to last like 200k. gst some syncromesh and it will make it go away</TD></TR></TABLE>
ROFL...well like most any other honda owners we all have the grinding tranny problem. ofcourse changing tranny fluid on a regular basis will help but in the end it's inevitable. now most trannys will start to grind closer to the middle of there life. around 200 000km's. now for instance my 91 teg grinds from 1st to 2nd when shifting hard. now anyone can make there tranny grind by shifting to fast...short shifters will not help this problem. what causes it??? simple: synchros's in your tranny are worn. try GM synchromesh as it's an additive that helps bandaid the synchro's and will help get rid of the grind. just try and rev match more and just don't shift so fast wit some snychromesh and you'll be fine for a long time to come. worked for me and i'm just shy of 300 000km's
yeah so then i should probably take it easy then for a bit? i mean i can get it not to grind if i wait like a second but then ima loose the race lol........................................so i should buy some stuff for it then huh?
Re: grinding into 3rd gear (IT'S ME DAVID)
i have the same problem in my 00 si, only in 3rd too some people told me to try the synchromesh, and the others just told me to drive my tranny into the ground
Re: grinding into 3rd gear (00 Em1)
it doesnt matter what fluid you put in there. its still gonna grind. your syncros will not the be problem and more simply because youre not grinding on the GEAR itself and it will need to be replaced as well. 9/10 times you cant just buy the syncro from honda anyway. youll need to get the entire 3-4 gear set.
Re: grinding into 3rd gear (Slammed Civic Si)
your gonna have to change the syncros, there is no way around it. get carbon coated syncros then you will never have that problem again.
