Got new ecu in but still runs like sh*t..
Old 12-06-2005, 11:00 AM
crazyhtch's Avatar
Default Got new ecu in but still runs like sh*t..
94 hatch with 97 d16 mini me swap...start rite up fine the wont go over 2000 rpms just revs up too 2000 rpms then just back fires..changed the ecu/spark plugs/spark plug wires/tps sensor/iac sensor/ anyone no wats wrong? would it b my timing? pls help..!!!
Old 12-06-2005, 11:02 AM
ZacCarter's Avatar
Could be your timing, what ecu are you running?
Old 12-06-2005, 12:34 PM
crazyhtch's Avatar
Default Re: (ZacCarter)
running a p28 ecu
Old 12-06-2005, 12:44 PM
SVOboy's Avatar
Is it chipped to run whatev maps? What head, d16y8?
Old 12-06-2005, 12:46 PM
Heylookits shawn's Avatar
Default Re: (SVOboy)
does it just sputter after 2k, or is it like it has a 2000 rpm rev limiter. is it throwing any codes? it sounds like its in limp mode
Old 12-06-2005, 01:10 PM
crazyhtch's Avatar
Default Re: (Heylookits shawn)
yeh its the d16y8 head...the check engine light isnt on..so its not throwin any codes..like wen it goes to 2000 rpms it sounds like rev limiter but it repeativly backfires...this is my 2nd p28 in the car n still doin the same thing...like wen its cold n i start it it revs open like it should to like 6500 rpms but the wen it gets warm the idle dropps n it wont go over 2000 rpms.. could it b a sensor?timing?o2 sensor/map sensor?
kustom_2323
Engine Management and Tuning
02-25-2011 07:41 AM
crazyhtch
12
12-14-2005 02:59 AM
crazyhtch
12-03-2005 07:00 AM
LS-G
04-01-2002 06:24 AM
Quick Reply: Got new ecu in but still runs like sh*t..
