got b16 swap, b16 guru's- pics and questions..
alright i got this swap for pretty damn cheap so i guess you get what you pay for...
please if anybody knows what's wrong with the pictures please post, thanks
1st pic, i know there's gotta be something, maybe a plate or something that needs to go here, i can see the flywheel, probably not good..
2nd pic, the crank pully seems to be aftermarket maybe, which i've read can be bad, also there is a notch like chipped out of it, need replacement?
3rd pic, i thought there were 2 bolts coming up, might be wrong, but does this mount look okay?
Thanks.
Thanks.
Re: got b16 swap, b16 guru's- pics and questions.. (whitehatch11)
1st pic...starter goes there
2nd pic..replace that shitty pully with an oem one
3rd pic..that mount is the kind that has one stud and the other hole is for a bolt and nut
what year/generation is that b16? its not a sirII
You are missing your starter in the first pic...
2nd pic looks like an UR underdrive pulley, it is aftermaket and aluminum. Get a OEM one. Look inside does it have a rubber kinda thing inside, torsional vibration damnper, the OEM ones have it.
3rd pic, the mount bolt is broken.
Re: got b16 swap, b16 guru's- pics and questions.. (Touge Panda)
Tough, wouldnt that be teh mount thats on the side of the power steering, that is secured to the chasis with 2/ 17mm bolts?
You may also want to replace the clutch while the engine is out of the car. 265 for an exedy you cant beat it.
Re: got b16 swap, b16 guru's- pics and questions.. (Moe)
on my b16 it has two studs and all you do is throw some nuts on them and its done..but some have one stud and one bolt and nut that goes all the way through
okay, hold up, i think he tried to pull something, is this a sirI or sirII? because the tranny doesn't seem to match up with the pic on hondaautomotiveparts.com of a del sol vtec tranny... **** help!! sirI or II???
Re: (whitehatch11)
More pics.... it shouldl be stamped on the engine/tranny bell housing.
Also the oil squirters are bigger on the 2nd gen B16's. Take the oil cap off and look...
Re: (Moe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moe »</TD></TR><TR><TD CLASS="quote">More pics.... it shouldl be stamped on the engine/tranny bell housing.
Also the oil squirters are bigger on the 2nd gen B16's. Take the oil cap off and look...</TD></TR></TABLE>
pr3 stamped on the back
front of block... just noticed, 1 million series
****, 1 million series means sirI doesn't it...?
Re: (161822)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 161822 »</TD></TR><TR><TD CLASS="quote">yeah 1mil. is a cable sir1 a 5 series is the hydro version.....sorry to hear that.</TD></TR></TABLE>
looks like i have a nasty email to write.. this sucks..
Re: (Touge Panda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Touge Panda »</TD></TR><TR><TD CLASS="quote">that sucks man...you need to research these things before you buy used motors/parts....good luck</TD></TR></TABLE>
no see he stated that it was a b16sirII swap, even talked to him on the phone about it... one way or the other i'm getting my money back...
Pr3 can come on both 2nd and 1st gen motors but yours has more of a offset on the drivers side mount and that with the serial number says it's pretty much a 1st gen. Yeah, get your money back and if he refuses post his addy.
Re: (Moe)
oil squirters are in the block....
Re: (b00st)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00st »</TD></TR><TR><TD CLASS="quote">still, if you did more research, then you would of known if he was lying or not...good luck getting your money back</TD></TR></TABLE>
no i wouldn't... without close up pics how was i suppose to know...
JustHere4ADay
14
12-17-2007 02:08 PM
mynameizstitch
08-31-2007 04:44 AM
89civicb16a1
05-16-2006 02:50 AM
