goin to the track want some tips befor i go....
Re: goin to the track want some tips befor i go.... (b18c5-EM1)
Lower your air pressure in your tires. Feather the clutch.
Practice will do more than anything else for your launch.
Re: goin to the track want some tips befor i go.... (Ricey McRicerton)
the thing is i have been practicing a lot and have lowerd my tire pressure what should i rev up to be4 i start ??
and at what point should my clutch be out at what RPM if that makes sense?
my best time is 15.9
Re: goin to the track want some tips befor i go.... (jun_the_master)
whenever i'm gonna launch i normally put it up to around your peak torque, which for me is around 5k, but for the 00' Si your probly more towards 7k i believe. but that would be a pretty high drop unless you can really feather the clutch off the line but you don't wanna smoke your clutch either. i would probly do around a 6k or 6500 launch
- tires at 20 psi
- feather the clutch out the box
- if you have adj. struts set them to the stiffest in the back and the softest in the front
- launch it at about 3.5 - 4k for starters and just work your way up until you master the clutch work
- most of all just have fun
good luck let us know the results
Re: goin to the track want some tips befor i go.... (tbud454)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tbud454 »</TD></TR><TR><TD CLASS="quote">- tires at 20 psi
Sorry to some what bring this back, just curious at to why you would make the front struts soft and rear stiff... Thanks
Re: goin to the track want some tips befor i go.... (JdmEGHatch6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmEGHatch6 »</TD></TR><TR><TD CLASS="quote">
Sorry to some what bring this back, just curious at to why you would make the front struts soft and rear stiff... Thanks</TD></TR></TABLE>
You want to keep as much weight on the front tires to help with traction. When you launch weight transfers to the rear of the car taking weight off of the front tires causing a slight loss in traction. If the rear shocks are sitffer it will counteract the weight transfer a little bit helping in traction.
FliiBoii
02-03-2012 07:50 AM
sporkcrx
08-20-2004 06:01 AM
