Girl needs help
New User
Girl needs help
I have a 96 honda civic ex
and my exhaust has a hole in it
i needa a different one to pass inspection
my boyfriend has a 94 integra gsr
he recently recked it and i want to steal his
exhaust, will it work on my car?
if not, what other exhaust will will fit my car?
are other ek hatches and coups exhaust universal?
Re: Girl needs help
96-00 coupe/sedan muffler will fit. hatches are shorter.
the integra muffler can be welded on, but im not too sure it that will pass inspections or not.
Re: Girl needs help
it wouldnt hurt to weld it on it should run around well where i go 50 to 60 dollars to weld it on as long as its oem and it has a cat your fine
Re: Girl needs help
but yes, ex/si is different midpipe/manifold
Re: Girl needs help
Where is the leak? Not sure a shop will weld a rusty pipe or muffler.
The money your going to pay for a short term fix could be better spent if you bought a new part.
BTW, welcome to the forum.
Re: Girl needs help
my bad. forgot to think about possible conditions of the current exhaust. I put a hole in mine and patched it cuzz it was cheaper. It really doesn't matter in the exhaust though....holes only hurt if they're in the header.
Re: Girl needs help
well, unless your motor is a b-series, it wont fit. the flange from your boyfriends integra is a different length and if im not mistaken a different size from.
i had this problem when i swapped a integra motor into my ek hatch. and my stock muffler was too short. so i had to run it open header for a little while.
New User
Re: Girl needs help
Thanks for replies guys
ill see what i can do before august comes around
because that when my inspection is due.
yes i did pass emissions but i didnt pass the inspection in general
because of my exhaust.
Re: Girl needs help
It will only cost you $70 dollars max to replace all the piping. I'm half asleep but if the hole isn't in your header, cat, or muffler - just have the piping replaced. The piping you get will be new and stronger and less likely to rupture again.
Re: Girl needs help
if you live in palmyra find a shop called redland exhaust, they did my friends exhaust and they're really good and also cheap. i'm sure they'll weld it up for you. they're close to, i live in hershey and they're like 20 min from here
Re: Girl needs help
Re: Girl needs help
what is the biggest factory size axle back? im looking for 2.5" or 2.25 min. axle back that is as quiet as stock or factory.
i know civic si is 2 inches O.D. so meaning 1 7/8 I.D..
sorry to jack thread but since we are on the subject for stock exhausts
Re: Girl needs help
yeah, my stock muffler came up about 2-3 inches short. i was going to extend it, but it was too much of a hassle, so i just drove it down to the shop where i had my piping done open header. lol.
New User
Re: Girl needs help
