getting more hp
getting more hp
by the end of the summer i will have a test pipe and headers added onto my car which already has ractive exhaust and GReddy SP exhaust system.my car is a 93 honda del sol.what else besides turbo charging it and nitrous can i do to give it some good hp gains??
Re: getting more hp (lucint)
it really all depends on whether you plan on going turbo in the future or staying with all motor, because you will buy parts that you will end up not going to use when you have a turbo. if you are going all motor some easy parts are cold air intake and headers. if you have the money some higher compression pistons or even maybe cams with cam gears. just a few suggestions.
The wealth of information on upgrades for NA applications are endless in this board...I suggest you do some reading and searching to...generally speaking I/H/E boltons will provide decent hp gains; furthermore you may look at upgrading your suspension and finalise this by rebuilding your engine with cams, etc.
Re: getting more hp (spoonedcivicG4)
get an CAI. it's a little pointless if u can't complete the air flow set up. by the end of summer, what is restricting you is your intake.
Re: getting more hp (red240ne)
if i were you spend 400 bucks on some cams and spend about 200 for adjustiables and polish that head tune that sucker u'll be stylin with HP
and for the last but least run on high octane for max HP, i got a buddy here with GSR only head work and is running 13s not bad just for headwork
[Modified by NiraCivicJDM, 10:07 AM 2/2/2003]
Re: getting more hp (NiraCivicJDM)
Unceasing Measure
Re: getting more hp (delslow94)
Big cams with camgears, p&ped head with titanium and stainless junk inside it, designed to make power to 10500 rpms, higher compression pistons with forged rods and better sleeves, 4.9 final drive, strip your car, etc.
Your best bet would be to become a better driver. Take some driving classes and never assume that you're a good driver: you can always wring more out of acar by changing the parts that sit in the driver's seat
Re: getting more hp (autoxdelsol)
is the car gonna be just drag or street/drag? if its 100% drag then id suggest you buy everything and start gutting it right now if its a street/drag daily driver then maybe some mild gutting and start working on the head and letting the motor breath easier
Re: getting more hp (acydphryck)
Eric, To make your car faster dont worry about HP. I sugest that you start at the top of a hill and race down it...lol J/k Instead of getting a new header and internals. Take the guy up on his offer of installing the B20 Engine and the new manual Tranny... youl haul........ also youl never be that fast with a 500lb system in your trunk... just my opinon
EM2Insta
Honda Civic (2001 - 2005)
29
11-11-2012 07:58 AM
4dr-Si
14
05-17-2006 08:39 AM
