gettin a b18b soon...help...
ok my boys friend is hookin me up with a b18b, 70k miles...
for 800 bucks...he said i need new axles... ok first is there anything i shuold be aware of, lookin at the motor? then... i really need rims + suspension... that was where my money was going, but i really want this motor... and its a offer i can't resist... im prolly gonna needa couple more hundred, for the swap to complete eh...ahh...my head hurts... |
Re: gettin a b18b soon...help... (jinusang)
Compression test that mang, you need new alxes, the tranny, ECU, mounts etc...
Good luck |
my friend said it comes wit tranny, ecu, harness, and pretty much everything except
axles and hydrualic cluth,for my 96 Ek |
Re: (jinusang)
As long as the compression is good and doesn't look like junk....take it. That's a really good price. I ran across a deal on the same motor and I jumped on it.
so, is that all i need?
rite now i think i need a b16 hydraulic clutch, and axles? anything else? im new to a swap... |
Re: (jinusang)
mounts, ecu....do a search. That swap has been done many times.
If it doesn't have a Hydro tranny then the motor is probably OBD 0, which is going to be a lot harder then an OBD 2 swap
hydro conversion 200 -300 adapter harness 200-300 this will turn your $ 800 swap into a $1500 swap if your lucky, plus the wiring headaches, and if your in cali, well thats a whole other issue |
Re: (egsleepercivic)
so its an old motor? for 800 dollars and its not complete? im sorry...but that sounds a bit high. i got a complete swap at a u pull... 98 motor. 250. look around bro..there are better deals.
oh ok thanks...
whew....no wonder it was so cheap... |
Re: (jinusang)
not to incite anything, or sound rude but a vin check just incase if its stolen.
