Generic CYP can cause breaking
Old 04-06-2017, 03:38 PM
carlos8's Avatar
Default Generic CYP can cause breaking
Hi, Civic ex 97 , fighting with breaking at wot. I have an OEM distributor but replaced the CYP with one from a ebay dist. Can this pick up been so bad quality that still working wrong? Planing on buy a b20 OEM dist. for $40 to replace it.
Old 04-06-2017, 10:53 PM
Hysterically Calm
TomCat39's Avatar
Default Re: Generic CYP can cause breaking
I've heard others say after market distributors tend to be garbage. They say they have a box of brand new bad dizzys.
Old 04-07-2017, 05:49 AM
mk378's Avatar
If you're talking about misfiring at heavy throttle, especially at low rpm, and no code thrown other than misfire codes, that is often generally weak sparks. Consider the plug wires, plugs, cap and rotor, and coil.
Mixing and matching parts between genuine and knockoff distributors probably isn't going to work very well. When you change the sensors make sure the gap to the reluctor teeth is small.
Old 04-07-2017, 06:24 AM
Txdragon's Avatar
Why not just replace the entire distributor instead of buying it, ripping it apart, and piecing together the other? Anywho.. Is the CEL gone? Are you still getting the sensor code? If the engine light and trouble code is gone, you may look at other possibilities like mk378 mentions.
Black R
12-06-2021 04:23 PM
j_moua
11-22-2019 11:09 AM
mortificationrock
03-21-2011 10:21 AM
tekstyle
08-17-2004 05:16 AM
ludelvr
07-18-2004 04:49 PM
Quick Reply: Generic CYP can cause breaking
