Gauges do not work! Need help... 93 civic LS swap
I have a 93 civic coupe Ex body with a 95 ls swap and my gauges do not work.. <U>None</U> of the gauges in the cluster work.. Any ideas?
Re: (btk2334)
ok i'm going to go double check my fuses.. They all seem to be good but wont hurt to check again.. If it is not the fuse where would the wires be located i need to check on and see if there is a short? Color? Cuz there is an octupus of wires from the previous owner underneath the passenger wheelwell and the wires on the driver side are wire tucked through the fender.. Thank you for your help so far
Re: Gauges do not work! Need help... 93 civic LS swap (BlackBeemer)
I Have the same problem wierd... did you ever find out what it was???? nothing in my cluster work but battery light, SRS light, Gauge lights, and Bright lights.
Things that don't work, Check engine,rpm,mph,coolant,fuel,brake,seatbelt,hatch,a nd clock probley forgetting some but you get the idea
NEED HELP BAD
NEED HELP BAD
jodyboy
01-05-2013 08:38 PM
kturner2007
12
01-09-2007 10:03 AM
kyutepnoy
07-29-2006 07:26 PM
