Gauge Cluster Wiring Diagram Help
Old 02-05-2003, 06:28 PM
Cody's Avatar
Default Gauge Cluster Wiring Diagram Help
I'm looking for charts/diagrams detailing the pin positions of the gauge cluster wiring harnesses of a 96-98 civic CX/DX and a 98-01 ITR. Any help would be appreciated. I've done a search and couldn't come up with anything. Thanks in advance.
Old 02-05-2003, 06:54 PM
INVALID's Avatar
Location: Why so you can pretend like youre interested, FL/OK
Default Re: Gauge Cluster Wiring Diagram Help (Cody)
http://www.jdmfan.com/technical/cosm...ntegra_cluster/
Old 02-05-2003, 08:27 PM
ace1875's Avatar
Default Re: Gauge Cluster Wiring Diagram Help (SHAUNTS99)
Does that also apply for EH's?
Old 02-06-2003, 12:24 AM
FifthGearOnline's Avatar
my link is dead, stop clicking on it
Old 02-06-2003, 05:27 AM
Cody's Avatar
Default Re: Gauge Cluster Wiring Diagram Help (FifthGearOnline)
i dont know how different the GSR, and ITR are, but when i did my cluster that page wasnt even close to being right
heres my install guide
http://www.fifthgearonline.com/installs/gsrcluster.htm
Thanks a ton everyone, the jdmfan one didn't work for me either, I originally tried Merrit's old one off of her site and I believe that it was specific to 99-00 EKs - the one on fifth gear worked great (and that was with the ITR cluster ). Thanks for the input.
btw, this was in a 96 CX.
Old 02-06-2003, 06:46 AM
ActionJackson's Avatar
I originally tried Merrit's old one off of her site and I believe that it was specific to 99-00 EKs.
could you post a link to this site?
[Modified by ActionJackson, 7:47 AM 2/6/2003]
Old 02-06-2003, 06:47 AM
could you give me the link to this site?
Old 02-06-2003, 09:55 AM
glad my site could help
edit: was it easy to follow, or should i change it a little?
[Modified by FifthGearOnline, 12:55 PM 2/6/2003]
Old 02-06-2003, 02:03 PM
INVALID's Avatar
Default Re: Gauge Cluster Wiring Diagram Help (ace1875)
This is for EG, but I am sure there isn't a difference, but here:
https://honda-tech.com/zerothread?id=304752
https://honda-tech.com/zerothread?id=364837
Old 02-06-2003, 02:06 PM
INVALID's Avatar
Dang my bad man, I could have easily put your site in there if I would have actually checked my list instead of throwing a link off hand cause I noticed I didn't even have the jdm fan link for the cluster in my wiring guides any longer. Looking at my current list I guess there was a reason for that.
Old 02-06-2003, 02:18 PM
SprayinCX's Avatar
i got the wiring for the cluster if any ever needs it
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
match the wire colors and solder and tape the connnections.. make a custom housing for the dash as the cluster doesnt fit perfect can it can be made to look nice.
i just got done doing this with gsr cluster this will help you allot.
Old 11-11-2006, 10:49 PM
dwillms's Avatar
I wanted to post because I couldn't seem to find accurate info quickly for wiring a DC cluster into an EK. Plus, I just spent an hour reading my Helm's to make sure my stuff is correct. I think the post above me is for an EG.
Anyways, hope this helps someone. I only put in stuff that needs to be wired, and left out stuff like the ABS, door sensor, maintenance light, low fuel that don't work or don't carry over.
1. -
2. -
3. -
4. yel dimmer
5. -
6. blk ground
8. -
9. wht/blu battery
10. -
11. yel/red oil pressure
12. grn/org check engine
13. blue tach
1. red/blu seatbelt
2. -
3. yel/wht fuel gauge
4. -
5. -
6. org speedo
7. grn trunk
8. -
9. red brightness
10. red/blk gauge lights
11. blk/yel VSS
12. -
13. grn/blu left turn
14. grn/yel right turn
15. red/grn high beam
16. grn/red e-brake
civic's left side blue plug (13 pins)
1. -
2. -
4. yel dimmer
6. red/grn high beam
7. grn/red left turn (1 silver stripe)
8. blue tach
9. -
10. -
11. -
12. red brightness
13. red/blk gauge lights
civic's right side blue plug (16 pins)
1. -
2. blk ground
3. blu/blk trunk
4. grn/yel right turn (1 silver stripe)
5. grn/red e-brake (2 silver stripes)
6. red/blu seatbelt
7. -
8. -
9. -
10. yel/blk fuel gauge
11. blu/wht speedo
12. yel/grn coolant temp
13. -
14. -
15. blk/wht VSS
16. wht/blu battery
I can confirm that this is right, because I just finished wiring up a 94 GS-R cluster into a 96 CX successfully.
-Dustin
Modified by dwillms at 11:13 AM 11/12/2006
mikehawk
11-07-2008 01:28 AM
EF9Si-T
02-16-2004 09:49 AM
rolow
12-08-2003 05:29 AM
Quick Reply: Gauge Cluster Wiring Diagram Help
