gauge cluster question
i have a 93 civic CX with a b16a, i just got my 93 si cluster in the mail today and i wanted to know about the wiring. are the wires for the tach already there on the CX or do i have to run a wire. and what do i do about the mileage. i was told that i could swap speedometer's, but how would i go about doing this. thanks for any help.
New User
Re: gauge cluster question (rookie2nr)
speedometers are easy, just pop off the tabs that hold the grey peice to the body of the cluster, then undo the three bronze screws in the back of the cluster behind the speedometer, and then switch the speedometers so your mileage is accurate.
the wiring is already there. my dx didnt come with a tach, the CTR cluster which does have a tach worked perfect. honda doesnt take the time to create different wiring harnesses for different trims. the equipment is different though.
i got a question, i have a 94ex and im about to order a b16a2. is there any way i can use the si gauge faces? it dosent line up correctly. my tach stopper is paraell with the tach, the Si one is about 30 degrees lower. is it possible to change this?
Re: gauge cluster question (KAMiN)
you mean the 99 si faces or the 94 si. u don't really need to get the 99 si faces. your tach goes to 9000 anyway.
V.MoMO
09-12-2010 08:44 AM
TurBros
22
02-12-2006 07:20 PM
Littlegreend15
03-19-2005 02:41 PM
Griffin@Camtech
03-29-2004 06:20 AM
