gauge cluster back lights
i need to know what wire is the illumination wire for the gauge cluster on my 93 del sol... what color is it, what pin is it. a pic would be sweet. i havn't been able to see the speed or rpm in my my car after dark since i got it 4k miles ago
Re: gauge cluster back lights (4ghatch)
my stock ones dont light up at all!! its not a fuse (none are bad) and the heater and ac lights work good with the dimer too. no cluster back lights
what makes you think it's a wire? It's probably burnt out bulbs. I think the bulbs with the brown bases are the ones that light up your cluster
Re: gauge cluster back lights (dohctor_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohctor_B »</TD></TR><TR><TD CLASS="quote">what makes you think it's a wire? It's probably burnt out bulbs. I think the bulbs with the brown bases are the ones that light up your cluster</TD></TR></TABLE>
x2
Its the bulbs
https://honda-tech.com/zerothread?id=661308 (92-95 guage)
https://honda-tech.com/zerothread?id=1186091 (96-00 guage)
x2
Its the bulbs
Re: gauge cluster back lights (97Ej6mike)
i really dont think its the bulbs i have 2 extra clusters like 8 bulbs each! i doubt they are all bad and all look good. the reason i think its a wire is because i got the car with the white faced gauges and they didnt even light up right ether. after i swapped the cluster it never worked again... the other reason i think its a wire is i had to rewire the rpm wire cause it was cut!
someone here has a link to the dash harness wiring im sure.
95jdmcivic
Honda Civic (2001 - 2005)
05-15-2014 06:58 AM
Stevo2427
10-04-2007 10:40 AM
