Gated Shifter Insert Accessory
Old 06-10-2003, 06:12 AM
brenerb's Avatar
Default Gated Shifter Insert Accessory
Ok hang on everybody im going to go RICER on your ***.
Has anyone ever seen a "Gated Shifter Insert for a Civic? Someone let me know if it even exists.
Old 06-10-2003, 06:32 AM
Ricey McRicerton's Avatar
Default Re: Gated Shifter Insert Accessory (brenerb)
Im pretty sure you could make one...seems like it'd be pretty cool to me!
Old 06-10-2003, 06:49 AM
99SilverVTi's Avatar
until you drop your loose change into it
Old 06-10-2003, 07:45 AM
Mike_C's Avatar
pretty cool idea actually.
Old 06-10-2003, 07:51 AM
tonyxcom's Avatar
Default Re: (JMU1337)
Actually, its a horrible idea. The shifter is just going to bang around in there when you are on/off the gas and on/off the breaks.
Old 06-10-2003, 08:43 AM
brenerb's Avatar
Does anyone know of a way to stabilize the shifter so it would not move around when driving?
Old 06-10-2003, 08:45 AM
mixmastabob's Avatar
Default Re: (brenerb)
For some reason my friends 82' VW has less shaking in the gears when hes on the gas then my Civic does. But then again it has about 10x the play in gears haha
Old 06-10-2003, 08:49 AM
tonyxcom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brenerb &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know of a way to stabilize the shifter so it would not move around when driving? </TD></TR></TABLE>
Solid motor mounts.
Old 06-10-2003, 09:54 AM
BigZ88's Avatar
Default Re: (tonyXcom)
my damn shifter has about an inch of play in it while in gear... (side to side that is)
Also, the reason for this movement in our shifters is cause of the shift linkages and no use of cables. Cable shifters dont move around much while driving.
Anyone know which poly inserts to use for a JDM b16 shift linkage? like the one on the motor? Are all b-series the same? cuz my d-series was MUCH too small to fit the hole.
Old 06-10-2003, 09:58 AM
tonyxcom's Avatar
Default Re: (BigZ88)
I think all b series linkage have the same larger end, so any bushings for an integra would work.
But your shifter will still move. When you acclerate and brake hard, you motor moves forward and back. Since your shifter is attached to the linkage which is attached to your tranny which is attached to your motor, your shifter will always move.
Old 06-10-2003, 10:34 AM
BigZ88's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom &raquo;</TD></TR><TR><TD CLASS="quote">I think all b series linkage have the same larger end, so any bushings for an integra would work.
But your shifter will still move. When you acclerate and brake hard, you motor moves forward and back. Since your shifter is attached to the linkage which is attached to your tranny which is attached to your motor, your shifter will always move.</TD></TR></TABLE>
agreed, im tryin to get rid of sideways movement
Old 06-10-2003, 11:16 AM
Mike_C's Avatar
my shifter feels sloppy, will new bushings help this?
Old 06-10-2003, 11:33 AM
BigZ88's Avatar
it should help a bit
CTR-GSR
02-24-2006 09:47 PM
Kyles ej1
14
10-02-2005 09:27 PM
eghatchomar
02-03-2005 09:52 PM
ScareyH22A
Honda Motorcycles
27
08-16-2004 10:53 AM
TurboEg
08-11-2003 07:50 AM
Quick Reply: Gated Shifter Insert Accessory
