Gasket matching a z6
Ok, I am almost done with a light porting on this z6 head I've been working on and it hit me... Should I gasket match??? There is a decent amount of material on both exhaust and intake side that could come out. I plan on keeping it na, it's going on a y7 block, and I'm shooting for high compression. Understand, this is a labor of love, and if it helps any, I'm going to do it. Please don't give me, "don't waste your time, just engine swap" or some junk like that. If it makes any posative difference at all, I will do it. I just want to know if anyone here has had experience with gasket matching a d series head, and if it will have any negative effect on performance. Should I may one side and not the other? Both? Neither? I want this thing to flow as preficient as possible, but I don't want to screw up this head. Thanks in advance.
Re: Gasket matching a z6
I'm curious to know what research you have done regarding runner size, length and intake manifolds etc.
The reason I ask is bigger isn't always better.
From what I understand, changing runner sizing shifts the power band but doesn't necessarily add anything and sometimes you lose a bit.
You are absolutely right TomCat... chances are really good that anything you do to a Z6 cylinder head will likely reduce performance somewhere in the power band when being used in a naturally aspirated application. Usually this occurs in the low to mid range... and peak power remains unchanged. Gasket matching reduces velocity... and reduced velocity reduces volumetric efficiency.
There is only bits and pieces of information out there. I was trying to research formulas for engine building purposes and ran into a snag when it came to intake theory.
Here is some of the bits and pieces... Long small runners build velocity in the air, fat runners have more air volume but at slower velocity (speeds).
Also on the subject of flow benches, guys have opened their IM's so the flow bench shows higher flow rates through them (fatter openings, runners etc. But when dyno'd the car lost power as the velocity was also impacted. I learned the flow bench is only a part of the equation and does not represent a full picture. I also learned the theory behind it all is fluid dynamics or fluid physics which is one of the most complicated maths around. The same maths used to calculate weather systems etc.
I think it's great you want to practice and learn about port and polishing, I just wanted you to not be disappointed if the results of your efforts actually go reverse of what you were/are hoping for.
I'm honestly not trying to be negative, but unless you're great with math and/or are studying engineering, doing internet research on fluid dynamics isn't going to get you very far. I'm a mechanical engineer and fluids was part of my BS engineering program, but at the undergrad level you barely scratch the surface. Deeper understandings are usually gained at the graduate levels. There are CFD software packages (like SolidWorks) that allow you to either create or import a model and run fluid simulations, but you'd still have to be able to accurately interpret the (simulated/theoretical) results and apply them to real world applications. To me, porting is one of those things I would just leave to the pros.
If you are doing your own tuning, that will tell you what you need for each change.
If you are porting before learning how to tune, you are doubly blind and will have no clue what the car needs until you learn how to tune.
I'd suggest learning to tune before you change anything, then start your changes/porting so you can retune each step of the way.
haroldthefly91crx
08-14-2006 08:26 PM
Wes90civic
01-19-2004 11:13 PM
