gasket ?
gasket ?
i bought a LS/VTEC swap and im re-doing some of the work on it and had a question about an intake manifold gasket. I need a new one and i dont know what one to buy and what year to get. The block is a 94 and i dont know what year the head is. Its a PR3-4 I believe. So i just need to know what one to buy. Thanks
Re: gasket ? (TurboEK9Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEK9Coupe »</TD></TR><TR><TD CLASS="quote">i bought a LS/VTEC swap and im re-doing some of the work on it and had a question about an intake manifold gasket. I need a new one and i dont know what one to buy and what year to get. The block is a 94 and i dont know what year the head is. Its a PR3-4 I believe. So i just need to know what one to buy. Thanks </TD></TR></TABLE>
I dunno, maybe I missed something, but an LS/VTEC can be w/ any B series VTEC head, most commonly w/ GSR and B16s.
Are you telling us for sure if it's a PR3, or are you asking?
B16 = PR3
LS = PR4
GSR = P72
At least I'm pretty sure that's what they are - I'm pretty sure the heads share the same codes as the pistons - but I could be wrong on that one, somebody please correct me if I am. Any B series gasket should work though as they all have the same manifold bolt pattern...
B16 = PR3
LS = PR4
GSR = P72
Darth ModerVader
Re: gasket ? (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">Any B series gasket should work though as they all have the same manifold bolt pattern...
They actually don't, which is the reason why a B16 or ITR intake manifold won't bolt on to a GS-R head.
I'm a little confused by the original question also. If you have a PR3 head, just pick up a B16 intake manifold gasket. Is there something else I'm missing?
Re: gasket ? (Padawan)
No i was wondering what year, make and model of a car so i can get the correct one to buy. So any car with a B16 that i buy the gasket for will work with my PR3-2 head. Thats all i wanted to know so when i go to NAPA i can tell them what car it is from. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
I'm a little confused by the original question also. If you have a PR3 head, just pick up a B16 intake manifold gasket. Is there something else I'm missing? </TD></TR></TABLE>
Oh wow, didn't know that, good knowledge .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEK9Coupe »</TD></TR><TR><TD CLASS="quote">No i was wondering what year, make and model of a car so i can get the correct one to buy. So any car with a B16 that i buy the gasket for will work with my PR3-2 head. Thats all i wanted to know so when i go to NAPA i can tell them what car it is from. Thanks
Yes, if you have a PR3 head any gasket for a B16 will work. Yes the B16 changed slightly from the ones in the del sol in OBD-I to the 99/00 Si but the bolt patterns are the same, they didn't do any drastic changes. Yes, any B16 IM gasket will work.
I don't know what a PR3-2 head is, I know a PR3 head is a B16 head, but I don't know where the two is.
As far as year though...I never looked into it nor verified it but I'm pretty sure there's a date stamped on the front of the head above the header some place (somebody else can verify or exclude this suggestion). Should say something like 9/99 or some **** like that.
Re: (210EGhatch)
Thanks for the help guys. Yea the year of the head is a 91. The guy that i bought the swap from didn't know anything about the motor and i have had nothing but trouble since i have put it in my car. A month after i put it in, one of the rod bearings was gone. Then last december i had to rebuild the head and now i have to fix the leaking head gasket. I know that their can be problems with the head gasket leaking by the exhaust manifold, and what is the best way to get everything to seal up?
Re: (TurboEK9Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEK9Coupe »</TD></TR><TR><TD CLASS="quote">Thanks for the help guys. Yea the year of the head is a 91. The guy that i bought the swap from didn't know anything about the motor and i have had nothing but trouble since i have put it in my car. A month after i put it in, one of the rod bearings was gone. Then last december i had to rebuild the head and now i have to fix the leaking head gasket. I know that their can be problems with the head gasket leaking by the exhaust manifold, and what is the best way to get everything to seal up?</TD></TR></TABLE>
It should seal fine w/ the new gasket.
If it's warped though you have to get the head milled and the block done a bit (block's usually not necessary, but it ensures it).
If it's not warped it should seal w/ proper lb/ft. tq. in the right torque sequence.
EDIT:
PS: Again your question is a bit on the vague side.
EDIT:
