gas gauge problem
gas gauge problem
i just bought a 92 vx hatch and its all stock and i noticed that when i take a right turn the gauge goes down alot like if i have 3/4 tank it will go to under 1/2 then when i go left it goes back up to 3/4 or higher i was thinking it might be a ground problem or the sending unit. does anyone have a idea of what it could be ?
Re: gas gauge problem (jdmcr-x1990)
The gas does move around and so does the sending unit. If your ever going down or up a steep hill, your guage will read different. Same thing goes for long corners at higher speeds. My guage goes very slow for the first half of the tank and the last half it tends to drop very fast. It is totally normal for a guage to move when driving on different angles. If it starts to read wrong (you just tanked up and it on E then get it checked). As long as it returns to the same spot when your finished turning or have the car level again then it's all good. What is the size of the tank for the Vx? The Dx is 40L I do believe. I think it is smaller so that might have something to do with it.
ya i thought it could be normal my crx doesnt move like that tho and sometimes i doesnt go back to what it should i forgot to mention that and the tank is 10gal from what the manual says
Re: (jdmcr-x1990)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcr-x1990 »</TD></TR><TR><TD CLASS="quote">ya i thought it could be normal my crx doesnt move like that tho and sometimes i doesnt go back to what it should i forgot to mention that and the tank is 10gal from what the manual says</TD></TR></TABLE>
You could have a problem with the sending unit. It may be becoming stuck or slow moving. You can check the voltage and signal on the unit itself. Try that and post the readings.
Re: (jdmcr-x1990)
my vx's guage sucks for accuracy, i just drive and if the front of the car is slightly lower then the rear, it will read more then i have, and vice-versa
Re: (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote">my vx's guage sucks for accuracy, i just drive and if the front of the car is slightly lower then the rear, it will read more then i have, and vice-versa</TD></TR></TABLE>
my ex does the same, this was brought up in another post and everyone seems to agree that ALLLL hondas do it
