FUSE PROBLEM
One night my tailights went out along with my cluster and corner lights.
So i replaced the fuses and everything was ok. It blew again and now everytime i put in a new fuse it immediately blows the moment i try to turn on the corners/tailights. what could be the problem? |
cmon i got a fix-it ticket and i needa fix it!!!!!
Re: (jerbear!)
my guess, check your ground
Re: (jerbear!)
sounds like a short
Re: FUSE PROBLEM (jerbear!)
yeah check all of the connections and make sure there is no wires sticking out or any metal connectors touching other metal because this will cause a short and blow your fuse
Hope this helps -Brian |
Re: FUSE PROBLEM (vtec69)
make sure the wiring to your headbeams isnt exposed in any way. If your headbeam wiring is arching to your corner lights, that would cause mad fuse blowage. ;p
