fuse keeps blowing
fuse keeps blowing
yesterday im driving and my cluster and blinkers stop working....the back up light fuse under the dash keeps blowing every time i turn the key to the on position...any ideas?
Re: fuse keeps blowing (gisserhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gisserhatch »</TD></TR><TR><TD CLASS="quote">yesterday im driving and my cluster and blinkers stop working....the back up light fuse under the dash keeps blowing every time i turn the key to the on position...any ideas?</TD></TR></TABLE>
you have a short (a wire is grounding out) some where. you need to take some time, a voltage meter, and start trouble shooting.
Re: fuse keeps blowing (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">you have a short (a wire is grounding out) some where. you need to take some time, a voltage meter, and start trouble shooting.</TD></TR></TABLE>
I loathe finding shorts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gisserhatch »</TD></TR><TR><TD CLASS="quote">cool...where do you think i should start?</TD></TR></TABLE>
i would suggest starting at the fuse box. or maybe at the dimmer switch being that is controls the lighting on the cluster. actually, when dimmer switches go bad they are the reason to lack of light on the cluster and dash. this might be your problem if the switch is bad and is shorting out.
Re: fuse keeps blowing (turbociviccoupe)
i have a cd player in there...it wouldnt hurt to check it out...also the fuse box and dimmer switch...
thanx..
thanx..
