fuse box
fuse box
ok so my car threw a code for the ELD (electronic load detector) and apparently you have to purchase the entire under hood fuse box. Honda dealership wants 250. just wondered if anyone knew where else to look beside ebay and the regular like that
Re: fuse box (EL Vap133)
my Haynes Manual says "you must aqcuire the entire underhood fuse box as the ELD cannot be purchased by itself
Global Moderator
You don't need to replace the whole fuse panel cover. You have a wire grounding out..
Check the white alternator wire..it could be grounding at the passenger strut tower. Follow the wire from the underhood fuse box to the alternator. Most likely it has rubbed through the insulation on the wire, and is grounding itself to the chasis..
Check all your wiring
Re: (Jimmy)
and that causes a code 20 for Electronic Load Detector. So wiring should fix that. also will a underhood fuse box from a 92 integra Da work on my 92 si hatch
Re: (Jimmy)
hey i wanted to ask u a few more ?s about my problems. couldnt figure out how to add you as a friend on myspace. if u get the chance look me up myspace.com/mountaindrew01
HondaHemi
11-27-2006 04:38 PM
