full swap Q's
full swap Q's
I've got a great deal on a 01 B18c1 longblock. I drive a 00 civic Si. Am I looking at a fairly easy swap here? Any recommendations from you guys, as far as mechanical issues and/or electrical? I'm getting everything, including the wiring harness and ECU.
Woohoo!
Woohoo!
Re: full swap Q's (4-banging)
Should be fairy simple. Mostly bolt-on ordeal. Go to http://www.hondaswap.com. It's chock full of info.
the only thing you'll need to re-use are your shift links and motor mounts.. the axles are interchangeable. Both motors are OBD2b.
Re: full swap Q's (redlinetuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigacuralvr »</TD></TR><TR><TD CLASS="quote">sell me your b16a2 with tranny then!!</TD></TR></TABLE>
not yet...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinetuning »</TD></TR><TR><TD CLASS="quote">the only thing you'll need to re-use are your shift links and motor mounts.. the axles are interchangeable. Both motors are OBD2b.</TD></TR></TABLE>
cool, thanks...
not yet...
cool, thanks...
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4-banging »</TD></TR><TR><TD CLASS="quote">I've got a great deal on a 01 B18c1 longblock. I drive a 00 civic Si. Am I looking at a fairly easy swap here? Any recommendations from you guys, as far as mechanical issues and/or electrical? I'm getting everything, including the wiring harness and ECU.
Woohoo!</TD></TR></TABLE>
you'll need to add the IAB wiring,and use the P72 ECU.
chris
chris
While you're at it, I would suggest for you to get a Skunk2 intake manifold so there would be no need for IAB wiring, and also a OBD-2 to OBD-1 conversion harness with a chipped P28 ECU. Everything else should be plug and play.
Re: full swap Q's (EVIL_EKology)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL_EKology »</TD></TR><TR><TD CLASS="quote">While you're at it, I would suggest for you to get a Skunk2 intake manifold so there would be no need for IAB wiring, and also a OBD-2 to OBD-1 conversion harness with a chipped P28 ECU. Everything else should be plug and play. </TD></TR></TABLE>
My plans are to get the JG E. Victor X...going turbo.
What is the IAB wiring and it's use..thanks
I believe the IAB is for the Secondary butterflies that are on the stock GSR intake manifold. The IAB solenoid opens and closes them at certain RPM's. I think to get rid of this you could also just not wire it and unplug the vaccum line to the secondaries. That way they will always stay open so there is no need for a switch to turn them on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL_EKology »</TD></TR><TR><TD CLASS="quote">I believe the IAB is for the Secondary butterflies that are on the stock GSR intake manifold. The IAB solenoid opens and closes them at certain RPM's. I think to get rid of this you could also just not wire it and unplug the vaccum line to the secondaries. That way they will always stay open so there is no need for a switch to turn them on. </TD></TR></TABLE>
Will the Victor X GSR style mani take care of this....as does the Skunk2?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4-banging »</TD></TR><TR><TD CLASS="quote">what after-market motor/tranny mount inserts would you all go with?
ES, Prothane, others?
Use your stock mounts
Re: full swap Q's (Ngo Power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ngo Power »</TD></TR><TR><TD CLASS="quote">
Use your stock mounts </TD></TR></TABLE>
should I replace the inserts to polyurethane ones?
