Fuel tank swap - DX tank to CX tank, how much weight saved?
I've gotta 1993 dx hatch with 11.9 gallon fuel tank. I have an opportunity to get a free 10 gallon tank from a 94 cx. How much weight is there to be saved? Is this easy to do? What kinda of precautions do I have to take?
Thanks
Thanks
Banned
Re: Fuel tank swap - DX tank to CX tank, how much weight saved? (jgop_151)
not much man.....just when u go to the track get it to where ur gas light is gona come on
Re: Fuel tank swap - DX tank to CX tank, how much weight saved? (On Point EK)
well...I don't think it's worth the trouble, but if you MUST know, it'll save you 1.9 gallons of gas.
Re: Fuel tank swap - DX tank to CX tank, how much weight saved? (SiDESLiDE240)
yeah I don't think it's worth the hassle, just don't go race with a full tank
Re: Fuel tank swap - DX tank to CX tank, how much weight saved? (CXHatchback)
Weight?? One gallon of water weights approx 8lbs so I think you'd be better of running with your gas light on and go on a diet too.
Re: Fuel tank swap - DX tank to CX tank, how much weight saved? (Civic242)
I think a gallon of gas weighs about 8 pounds and then there is the steel so you sill probably be saving 20-30 pounds.
1.9 gallons of gas (so basically 2 gallons) 16 pounds then approximately 5-10 pounds worth of steel and weight. So i think about 20-30 pounds.
[Modified by Extreme_Hybrid_Hatch, 5:19 AM 10/2/2002]
Banned
Re: Fuel tank swap - DX tank to CX tank, how much weight saved? (Extreme_Hybrid_Hatch)
I thought all 92-95 Civics were 11.9 gallons?
[Modified by blykins, 1:36 AM 10/2/2002]
Banned
Re: Fuel tank swap - DX tank to CX tank, how much weight saved? (Evil Civic)
if i'm not mistaken, i believe the 5th gen civics don't have gas lights
Thanks
Former Moderator
The CX/VX has a 10.0 gallon tank - the DX/Si has the 11.9 gallon tank.
Bigger STEEL tank would also mean that the tank itself is heavier even if both tanks are completely EMPTY.
But if you wanted to know exactly. Just get a empty 10.0 gallon tank and get a empty 11.9 gallon tank and the difference plus to gallons of gas is the weight you would save.
actually, something easier than that might be (if you want a close estimate) is that the gas tanks would be similar in design.
Weigh the cx (10 gal) tank, get the weight to size ratio and then just put in the larger gal tank into the equation.
My math skills are a bit rusty, but a ratio of size to weight should get you pretty close
I have no damn idea but we can conclude, its less steel, so its less weight, so you will be faster.
So if you want to be super fasty man and you are a weight reduction nut like Tom, and you are getting the tank for free then I say go for it.
[Modified by BenB, 9:28 PM 10/2/2002]
Re: Fuel tank swap - DX tank to CX tank, how much weight saved? (Inigo Montoya)
I will let you you guys know what the difference is, if and when I get it. Thanks for all the replys.
Re: Fuel tank swap - DX tank to CX tank, how much weight saved? (Dr. Beaver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. Beaver »</TD></TR><TR><TD CLASS="quote">if i'm not mistaken, i believe the 5th gen civics don't have gas lights</TD></TR></TABLE>
no wonder i keep running out of gas!!!!!! j/k
HT Order of Merit
Re: Fuel tank swap - DX tank to CX tank, how much weight saved? (B16aDasher)
Yes but if you swap in a JDM cluster, along with an Integra fuel tank, you should have a gas light... so ive heard.
SimbaDogg
02-29-2004 01:36 PM
WAFFLES
01-13-2003 01:15 PM
