Brake experts need help pushrod play?
Old 05-02-2012, 07:59 PM
JohnnyEF's Avatar
Default Brake experts need help pushrod play?
My 94 cx hb has some play after installing a new master cylinder. I made sure to bleed all the brakes. I am referring to the engagement point when the pads start contacting the rotor. It seems I have the push the pedal down maybe an inch before the car starts stopping.
It seemed by adjusting only the adjusting nut at the brake switch brought the play down dramatically. When adjusting the pushrod length at the pedal/booster it shortens or lengthens the throw? What does that mean actually? Seems like the helms talks about adjusting the push rod length for play? I am kinda of confused what the pushrod booster adjustment does? By only adjusting the nut at the brake switch helped out.
Helms states the pedal height to floor should be 6.30 inches. My car is at 5.0 inches anything to worry about? Any help would be appreciated
Old 05-02-2012, 08:04 PM
Silvertune's Avatar
Default Re: Brake experts need help pushrod play?
Did you bench bleed the master before you put it in?
Old 05-02-2012, 08:33 PM
JohnnyEF's Avatar
Yes it was bench bled. The car also had this issue with the play prior to installing the MC.
Old 05-03-2012, 12:31 AM
JohnnyEF's Avatar
bump
Old 05-03-2012, 02:05 AM
R.I.P. Mark
MRGRIM's Avatar
just adjust the rod
diffrent master will do that
dont panic adjust and forget
Old 05-03-2012, 10:23 AM
JohnnyEF's Avatar
Ok but adjusting the rod doesn't seem to affect the play? Only the adjustment at the switch.
Old 05-03-2012, 03:51 PM
R.I.P. Mark
MRGRIM's Avatar
adjust the rod further out to take up the play
yes there will be a little pressure on the rod
find a freind with a haynes manual and get the pedal height settings
your pedals might be set at wrong height to start with
cpthaegdon
07-22-2011 07:13 PM
G2hybrid
08-09-2006 09:26 AM
lv6l
12-04-2005 05:18 PM
mrduque
03-11-2004 02:02 AM
AzDrag1
05-14-2003 02:53 PM
Quick Reply: Brake experts need help pushrod play?
