Fuel Pump intermittent no Prime
Hello,
My cars fuel pump at times will not prime. The issue seems related to humid conditions. The issue resolves itself after some time, and seems at its most frequent when its raining/humid out. There is no check engine light that stays lit, the fuses related to fuel are good , and the main relay clicks, but sometimes you wont here the humm of the pump priming, which results in a no start. I checked for power at the fuel pump harness, and it does show about 12-volts kick in momentarily to prime the pump when the key is put in the on position. I changed the fuel pump out, but the issue will occasionally happen again despite no check engine light and main relay clicking. I swapped the main relay for a spare I have that's been re-soldered and I've placed dialectric grease where the harness plugs into the main relay to minimize effects of humidity but the issue still happens occasionally regardless of which of the two main relays I use. The ECU was recently (last 2 months) refurbished with new capacitors/etc. I checked the ground at the thermostat and it seems fine. Some things to consider:
Car is a 98 civic EX with a B series swap. I've searched this issue extensively on honda-tech but couldn't find any with similar issues to mine that were actually resolved. Any help would be greatly appreciated. If you need any additional details just let me know. |
Re: Fuel Pump intermittent no Prime
The problem you describe is generally a bad ECU. You can figure out if it is the culprit by swapping in a known good ECU. Do you have friends who can help?
Originally Posted by muellersfan
(Post 51958222)
I used to own a spare ecu for troubleshooting purposes , just like I own two main relays, but that spare ecu went bad on me and I haven't replaced it. Does anyone know if spraying silicone spray on the PCB would cause any issues for the ECU? Guys who run off-road RC cars spray their PCB's with the stuff, often to keep moisture exposure to the PCB from impacting its operation. |
The problem almost surely lies with a bad capacitor. Maybe the people who refurbished your ECU did not replace all capacitors or botched the job. I'd return it to them.
Alternatively, you can test installed capacitors with an ESR meter or desoldered/removed capacitors with a capacitance meter. Testing and replacing electrolytic capacitors is pretty easy. |
@Txdragon - take a look. Sounds exactly like the problem you're having.
Ok here's an update folks.
The issue came back albeit a bit differently. Fortunately I had purchased a spare ECU that arrived prior to the issue returning. Swapped the replacement ECU, and issue persisted. The car sounds like it wants to start but doesn't. It turns over, seems to bog and then shuts off. Giving it throttle as it attempts to start yields no difference. After some time, it starts just fine, as if the problem never existed. I went ahead and changed out the plugs, cap and rotor (plug wires are less than year old) after the car was able to start again on the old plugs, cap and rotor and noticed the plugs seemed burnt (probably from running lean due to no fuel?) I've heard some folks tell me its the starter, but it seems to crank over when I turn the key, and I don't hear any grinding or anything from the starter. So back to square one. If anyone has any suggestions, please reply as swapping out he ECU did not resolve the issue. |
So is intermittent no fuel pump prime still part of the equation or did that disappear and new problems arose?
(Post 51964917)
If the issue doesn't return, then it must've been ignition related, and the plugs, cap, and rotor resolved it probably. I will keep everyone posted, and will make sure to check if fuel is priming when the issue occurs. |
The fuel pump priming has nothing to do with a cap and rotor.
If you have fuel pump problems then its a main relay problem. I recently had this issue with my civic as its been sitting in my garage in high humidity the past couple years. |
Originally Posted by Jimster480
(Post 51965418)
If you have fuel pump problems then its a main relay problem. I recently had this issue with my civic as its been sitting in my garage in high humidity the past couple years. They are not new relays though, so if it happens again, and the fuel pump doesn't prime, I may just purchase a new aftermarket main relay to remove all doubt. Both relays do click though, and the check engine light doesn't stay lit. When the issue returned, I didn't have enough time to check for spark or fuel before the issue went away, all I was able to do was swap in a good ECU (which didn't solve the issue, so swapped back to original ECU). |
Originally Posted by oresama
(Post 51965644)
That's what I suspect. I have two Main relays I use for troubleshooting purposes and the issue was present with both.
They are not new relays though, so if it happens again, and the fuel pump doesn't prime, I may just purchase a new aftermarket main relay to remove all doubt. Both relays do click though, and the check engine light doesn't stay lit. When the issue returned, I didn't have enough time to check for spark or fuel before the issue went away, all I was able to do was swap in a good ECU (which didn't solve the issue, so swapped back to original ECU). The car starts right up now every time without issue. |
An update.
The issue returned, and everything seemed fine (no check engine light on, main relay clicks etc) with the exception of fuel pump not priming. I decided to activate and deactivate the factory alarm system via the key-fob (which has been acting odd in the last few months) and the fuel pump primed but the car was hard to start. Gave it a few moments and reinserted the key to the ON position, let the pump prime for a bit, and the car started up like normal. I switched over my dash and dash frame to a 99-00 Civic and the factory radio needed for the 96-98 OEM alarm system wouldn't fit, so I had to remove the face of the radio, exposing the circuit board inside, in order to properly hide the radio behind the dash. I'm going to try and disable the OEM alarm system altogether while I search for a replacement OEM radio that's in tact. If the issue returns while the factory alarm is disabled, then that rules out the OEM factory alarm and leaves just the Main Relay as the possible issue. Thanks again for all the help and suggestions. |
(Post 51969366)
(Post 51969368)
What troubleshooting warrants this^ conclusion? Seems like a huge leap, but I may have missed something.
There's no "guarantee" per say that the issue will be a bad main relay, but its my best guess if the issue persists with the OEM alarm removed, given I've checked/swapped nearly everything else it could be. On the haynes/chilton manual, for no fuel prime issues, it does state to check the OEM alarm if so equipped, due to it having some sort of control over the fuel? For the last few months, the alarm has been inconsistent in responding to key-fob presses , even with new batteries installed on Keyfob, and me literally inches from the the car. Keyfob tests fine on key-fob tester too. Either way ill keep everyone posted. I feel we're getting close. |
The stock 98 Civic EX security system has a security relay that cuts voltage to the starter solenoid. It has no circuitry tied into fuel pump control.
In addition, it's quite uncommon for the main relays of 6th generation Civics to fail. In contrast, the main relays of 4th and 5th generation Civics were problematic.
(Post 51965644)
Was the fuel pump circuit altered for the B-series swap? Time to troubleshoot the fuel pump circuit. Willing to do some basic electrical tests? |
(Post 51969487)
In addition, it's quite uncommon for the main relays of 6th generation Civics to fail. In contrast, the main relays of 4th and 5th generation Civics were problematic. This^ key information is entirely inconsistent with either a bad main relay or bad ECU. Was the fuel pump circuit altered for the B-series swap? Time to troubleshoot the fuel pump circuit. Willing to do some basic electrical tests? Aside from a kill switch, the fuel pump circuit is stock/untampered from what I can see. |
(Post 51969981)
Sure. I've got a multi-meter. Any tips on what I should perform first?
(Post 51970082)
Does the fuel pump currently fail to prime despite the CEL turning on and then off after 2 seconds?
(Post 51970120)
Currently its working fine, but when the issue is present its just as you described: it fails to prime despite the CEL turning on and then off after 2 seconds.
When the problem is evident: 1) Unplug the main relay (MR) and use a jumper wire to short pin 7 to pin 4 in the free MR connector. Does the pump run? 2) Turn key to ON(II) and then use the jumper wire to short pin 5 to pin 4 in the free MR connector. Does the pump run? https://cimg2.ibsrv.net/gimg/honda-t...f5355c7558.jpg |
(Post 51970203)
Tests must be done when the problem is evident.
When the problem is evident: 1) Unplug the main relay (MR) and use a jumper wire to short pin 7 to pin 4 in the free MR connector. Does the pump run? 2) Turn key to ON(II) and then use the jumper wire to short pin 5 to pin 4 in the free MR connector. Does the pump run? https://cimg2.ibsrv.net/gimg/honda-t...f5355c7558.jpg Will do. The fuel pump issue seems to happen like clockwork after he car sits over the weekend. I'll perform these steps then and report back. |
(Post 51970490)
Thank You!
Will do. The fuel pump issue seems to happen like clockwork after he car sits over the weekend. I'll perform these steps then and report back. If the problem is evident and the wire jump tests do NOT make the pump run, then leave one pair of main relay pins jumped while you check whether battery voltage reaches the fuel pump connector.
Im in central florida, I have multiple obd1 ecus if you need to test lmk
So the issue came back today, of course just before i had to leave for work....
I followed the steps and the results were odd. Here are the results..... Initial attempt..... When the problem is evident: 1) Unplug the main relay (MR) and use a jumper wire to short pin 7 to pin 4 in the free MR connector. Does the pump run? No 2) Turn key to ON(II) and then use the jumper wire to short pin 5 to pin 4 in the free MR connector. Does the pump run? No Second attempt after having to wait for rain to clear... When the problem is evident: 1) Unplug the main relay (MR) and use a jumper wire to short pin 7 to pin 4 in the free MR connector. Does the pump run? Yes 2) Turn key to ON(II) and then use the jumper wire to short pin 5 to pin 4 in the free MR connector. Does the pump run? No ------------------------------------------------------------------- I had a multimeter on the pump harness checking for voltage the whole time. Issue went away for nearly a month and a half and today returned out of nowhere. At time of issue, should I have tested for voltage at pins 4 and 7 to check if power was reaching the harness? ------------------------------------------------------------------- "....then there's a wire open between the main relay and fuel pump (kill switch-related problem?) or poor pin contacts in a connector that the wire runs through." I will try checking here next? Or should I consider something else? |
any update on this guys? having the same problem as well...
When the problem is evident: 1) Unplug the main relay (MR) and use a jumper wire to short pin 7 to pin 4 in the free MR connector. Does the pump run? No 2) Turn key to ON(II) and then use the jumper wire to short pin 5 to pin 4 in the free MR connector. Does the pump run? No |
Originally Posted by Jemm01
(Post 52288997)
