fuel problem works then dont HELP !!!!
yes , i have a 93 delsol with a b18c in it
my problem is that some times when i go to get in my car for the frist time for the day it wont start turns over but no fuel ive narrowed it down to its not the fuel pump and not a relay no short or grounding going on
the fuel pump just wont prime if i sit there and try turning the car off and to the on postion over and over again it will prime but wont work all the time
it happens the most when its hot outside and when i go from my house to the gas station put gas in or just getting somethin from there it wont start after
i had the same problem with my 90 crx i had but i would play with the relay under the dash and it would start
Re: fuel problem works then dont HELP !!!!
just had a problem like that in my 92 eg hatch. one day it wouldnt start then it finally did i noticed the fuel pump wasnt priming until the last time before it started. then about 3 days later it completly died. i replaced the main relay and the fuel pump has been working good since.
chickenandpickles
07-18-2005 11:11 AM
jhr1969
06-05-2005 04:00 PM
