FUEL PROBLEM
FUEL PROBLEM
i got a 98 hatch with a stock gsr in it no fuel pressure regulator or n e thing now since i have a walbro 255 hp fuel pump could that be rich and maxing out my injectors? which cause a code 16 which is for injectors?
Re: FUEL PROBLEM (SkIp_Civic_Ek6)
ok im dumbfounded,changed ,ecu,tps,injectors,distributor, rewired the injectors,even checked the o2 sensor,timing,unless the fuel pump isnt supplying enough fuel im ******* lost!!!!
