Fuel pressure = 55psi with walbro pump and civic si fpr?
got a walbro 255 high output and a civic si FPR and im getting 55psi at idle is this high? what could cause this to be so high?
Re: Fuel pressure = 55psi with walbro pump and civic si fpr? (turbotime)
55 is high for stock. I run at about 42 psi on my GSR.
Its the huge fuel pump, unless your running a turbo you dont need that big of a pump.
Re: Fuel pressure = 55psi with walbro pump and civic si fpr? (fasthatchb18c1)
hes running a turbo on his
my is running around 50 with stock fpr
the fuel pump is overpowering the fpr so thats why it went up.
you will be fine with a turbo setup
Re: Fuel pressure = 55psi with walbro pump and civic si fpr? (komat)
I thought you went to get tuned? What was your fpr then? If you changed it i would go back and get retuned.
yeah it got tuned on the civic si fpr i was just wondering if it was supposed to be that high even the tuner seemd a lil surprised
Charlie Moua
21
02-11-2011 05:54 AM
jordan_civic
05-23-2008 04:18 PM
Dominic-CTR
11-16-2003 10:53 AM
