Fuel filter/pump/hose problems
I've got a 1993 Honda DelSol Si and recently, I've been having more and more problems with the car starting up, idling low and dying. It's usually right after I get gas or if I romp on it a lot. It'll start right up if I mess with the hose a little bit.
I doubt it's the filter, because I just replaced it or the spark plugs cuz I replaced those too. I keep getting told it's either the filter, pump, hose, or spark plugs.
Re: Fuel filter/pump/hose problems (niffer_marie)
could be the pump. Marie. hopefully you get this problem solved. hey. if you ever find yourself in the sac, CA area. give me a ring.
Re: Fuel filter/pump/hose problems (JMaxx)
You have another aspect that you are overlooking. You check your timing yet? (cam, ignition) Also, any codes?
Re: Fuel filter/pump/hose problems (turbogixxer)
Eh, yeah, I forgot about my timing...it is a little off. Thats probably it. I hope it's not the pump though...I'm too poor to replace that! Thanks!
ZCcivic91
04-07-2007 10:52 PM
