fuel dumping out of canister
hello all, recently just did a bunch of work on this 2000 si due to water contaminated fuel. no o ring on the fuel cap. had 5 gallons of water in the tank and siphoned the water and debris from the tank. replaced fuel pump, sock, filter, and tested spray pattern. compression checked and found the rings to be washed and only had 105 psi in 3 out of 4 cylinders. no head damage. replaced the bottom end and now it runs. while running it seeps a fuel like fluid out of the vapor canister and im not sure where to go now to fix it. I was about to run codes to see if p1457 came up but the obd1 computer wont read it. im about to swap the p2t into it to see what I can find next. does anyone have any insight on the situation? thanks.
Re: fuel dumping out of canister
after approval bump
Post pictures of leak location.
mudpuppy4life
01-31-2015 07:34 AM
blinger
09-01-2007 10:35 PM
jdm5lughatch
31
05-17-2004 02:46 AM
