fucked up my second gear
#26
Re: fucked up my second gear (ABK)
good point abk.. i have another question if i take this to a shop what do you think they will tell me is wrong with it?
#28
Re: fucked up my second gear (jdm123)
Well if you grind into second upshift or downshifting, it's like 99% messed up synchro. And maybe bent shift fork. If it's a d series tranny I wouldn't even bother. Because for $100-200 you can get ex/si tranny from z6 or y8 and put it in yourself in a day if not less.
#30
I don't know about putting it in in a day especially if it is his first tranny in that old of a car it may take a day to get the axels off. Be sure that you get a good low mile tranny and while you are in there change the clutch
#31
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">Well if you grind into second upshift or downshifting, it's like 99% messed up synchro. And maybe bent shift fork. If it's a d series tranny I wouldn't even bother. Because for $100-200 you can get ex/si tranny from z6 or y8 and put it in yourself in a day if not less.</TD></TR></TABLE>
Definitely not a bad idea at all.
#32
Re: fucked up my second gear (green00EX)
it's a 99 so it's not old.w in oder for me to understand why i would do that i need to know everything it does so if you please i will throw it back to you?
#35
oh I think I get what you are saying. the axles run into the tranny if you change trannys you need to pull the axles. This can be tough even on a 99 sometimes those bastards seem like they will never come off. You will also need to pull the axles if you change the syncro to get the tranny apart
#36
You would basicly get a tranny without messed up synchros, or shift forks (or other internals). You just got to make sure that the person that you are buying a tranny from lives close by and incase it is messed up just give it back to him.
#37
Re: fucked up my second gear (bgoetz)
damn i would like to call this a learning experience. anyway so i f i bought the tranny but the snycro's wer ethe problem i would just have to get new snycro's to?
#38
in short: Your tranny is conected to the crank through the shaft your crank turns the gears in you tranny were all kinds of crazy **** goes on. This then turns the differential and finally your axles that are conected to your tires and the car moves. Your syncro is among the all kinds of crazy **** and is would be alot easier to replace the entire tranny
#40
alrigth i'm finally getting this. so gettin a whole new tranny would be better than just gettin the snycro's replaced?
#41
better bic you will not need to hunt the problem and although I am begining to question this you can do it yourself
#43
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm123 »</TD></TR><TR><TD CLASS="quote">alrigth i'm finally getting this. so gettin a whole new tranny would be better than just gettin the snycro's replaced?</TD></TR></TABLE>
It won't be better (in most cases), it's just cheaper and more reasonable. The only reason y I would try to rebuild the tranny if I would need a stong tranny to take alot of torque and alot of abuse. It costs alot and is just not worth it.
#44
well if i juist bought another y7 tor a y8 tranny cause as of right now i;m running a bone stock d series engine.
#45
yankin a tranny should only take 4 hrs even for an amature w/ little mechanical knowledge. any guys with experience can have it done in 2 hrs give or take. its actually a really easy process. ppl like to make it out to b a big ordeal when its not.
#48
The thing that I always recommend in this situation is fixing the tranny you have. Why? Because you could go out and buy a tranny that has synchros worse than the ones in your transmission now.
Just suck it up like a man and either replace the synchros yourself or have someone GOOD rebuild the tranny with new synchros. Replace them all and be done with it.
