Front Sway Bar for my 97 CX: SI vs CTR vs ITR
I have a 97 CX is search for a front sway bar.
I know you have to use the front lower control arms from a EX, SI, or CTR.
Do have to use the shock forks also?
What are the differences between the SI, CTR, and ITR sway bars?
I know the SI is a 26mm bar.
Is there an advantage to the Type R bars?
Can a ITR bar work in my EK?
Thanks in advance.
Thanks in advance.
Re: Front Sway Bar for my 97 CX: SI vs CTR vs ITR (a_kaibigan)
isn't there a problem with subframe damage with using a bar that TOO big for the string rates? Or is that only with rear sway bars?
Re: Front Sway Bar for my 97 CX: SI vs CTR vs ITR (d15 dirk)
actually looks like the ITR won't fit:
https://honda-tech.com/zero...60508
https://honda-tech.com/zero...50457
but the Si & CTR have the same setups!
