Front Strut Bar?
Front Strut Bar?
Hey guys just wondering if a front strut bar would make a huge difference and how much one would cost? What Kind?
Re: Front Strut Bar? (BlueIntegraBoy)
my tanabe strut was stiff as hell and made a huge difference, but like most suspension products they work best in combonations with others like sway and coilvoers
the 3-points are the best but i cant tell much difference other than when you have some super sticky tires on there. even then its not a huge difference. it's not very cost effective and its better to spend money elsewhere.
maybe you will feel the diff..if you drive hard into corners..but it will work better if you have installed the right bars for your car..
suspension components must be looked as a whole system..so everything will be balanced..and it must taper to your driving habits
Unceasing Measure
Re: (EK_B)
I've had the best results from the Neuspeed four-point. It helps turn-in a lot and makes for smoother transitions in direction and elevation. It's not a "huge" change, but it's one that you'll notice if you pay attention.
Re: (Archidictus)
got a front strut bar on my ek an I know that I cant really tell the difference but also my suspension is shot to **** and needs a new everything when taxes get here.
i used to always get the neuspeed bars..
then i started using the stock gsr type bars.
i think the 3 point ones are mainly for show and not worth the money.
if you actually look at your engine bay, the firewall is less than a foot from where the bar mounts, and is much stronger i'd think.
Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">
They are and the aren't. As with most else on H-T, it's a bandwagon part. I'm not saying it doesn't work, however most people don't track their car and take full advantage of it. Hell for what you pay for one, you can almost build a suspension.
There's really no point to a 3-point in a DD. My OEM Si one works fine for me.
Honda Sebas
Honda Civic (2001 - 2005)
06-28-2011 09:22 PM
