Front Lower Tie Bar
Front Lower Tie Bar
So yeah my question is, is this a good thing to put on? I hear it's pretty harmful to the steering. Should i just stick to getting better sway bars from an Si or something? Let me hear some thoughts on this.
Thanks..
Thanks..
Re: Front Lower Tie Bar (hatchback97)
well i put one on a 93 hatch and the driver of the car said it didn't do anything at all. so as far as i can tell they are a wast of $
get the swaybars
get the swaybars
They're supposed to give rigidity to your chassis but I doubt you would notice the difference. IMO swaybars would be more important if you do not currently have them already.
i had one for awhile and noticed that it was harder to make fast turns on the highway so i took mine off and gave it to a buddy. from what i hear and was told, front wheel drive cars shouldn't have those if you want to road race or auto cross. the rear however, should be solid. so try getting rear sways, rear tie bar and rear strut bars.
Re: Front Lower Tie Bar (shermanyang)
Got a noname one Last year. It was awesome. Made a real noticable difference. The front stays planted and I didn't even realize how sloppy the front was till I got it. If you get any bar at all this should be at the top of the list. Only one that really does make a change in the handling. The one I have triangulates the whole front end.
Only problem is no one sees it and how cool it looks.
Re: Front Lower Tie Bar (turboman)
Re: Front Lower Tie Bar (RokketRide)
Isn't there one from Cusco that mounts to 3 different points, and it's flat for added clearance? I'm not sure what cars it's made for, but it looks really solid. For the front, I just added a front lower bar, but it goes over cat, comes stock on 94-up Integras, and all 92-95 Civics have the holes pre drilled from the factory. Made a noticeable difference in handling, but most importantly stability.
Like I said it was a noname but looked real solid. I had it for 3-4 months before installing it. I wish I knew who I got it from because I would really recomend it to everyone. It connects at the front just like the nuespeed but then has two bars that go back and connect to the firewall.
That being said, I would want the springs on my shocks to control my handling, not flex in the chassis. Now weather or not you need lower tie bars is up to you, but they definetley cant hurt.
And if you think adding one takes away traction, then your car has other problems that need to be addressed or adjusted.
Re: Front Lower Tie Bar (tonyxcom)
Sorry...let me correct myself. i meant front front sway bars. if your'e gonna autocrossing or want the best traction for a front wheel drive car get this for your front setup:
soft springs, small (or no) sway bar, shocks w/ stiff compression and soft rebound. this will keep your front wheels planted. and i guess the front lower tie bar may help.
