FRONT LOWER EJ8 & CIVIC TYPE R CONTROL ARMS - ARE THEY INTERCHANGEABLE?
I HAVE A 97 CIVIC COUPE ,O.E.M. CONTROL ARMS IS THE WAY TO GO RIGHT,SINCE NOBODY MAKES THEM AFTERMARKET BUT I FOUND A SET OF FRONT EK CIVIC TYPE R LOWER CONTROL ARMS W/ THE SWAYBAR REALLY CHEAP CAN THE ARMS & SWAYBAR BE INTERCHANGED????
Re: FRONT LOWER EJ8 & CIVIC TYPE R CONTROL ARMS - ARE THEY INTERCHANGEABLE?
Danng this is a good one!!! ......will get back on this one!!
Someone has to know this, c'mon people
Maybe this helps understanding the fitment......it looks like it worked for this guy
http://www.ozhonda.com/forum/archive...p/t-60274.html
The lower control arms are a bit different. They can be interchanged, but you'll also need new shock forks cause the ones on there now won't fit. The 99-00 Si shock forks are the same as the CTR. So are the lower arms. The CTR sway bar is way thicker. Are you running a rear sway bar? Cause all you are doing is introducing more understeer into your ride.
http://www.ej8squad.com/thread-9665.html
http://www.jhpusa.com/store/pc/viewP...idproduct=1908
