Front disc won't come off
Hey everyone...working on my 98 civic.Got the pads and bracket off,then the two X screws.Now the disc won't come off.Anyone know how to get it off.
Re: Front disc won't come off (ironryder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironryder »</TD></TR><TR><TD CLASS="quote">Hey everyone...working on my 98 civic.Got the pads and bracket off,then the two X screws.Now the disc won't come off.Anyone know how to get it off.</TD></TR></TABLE>
Have you removed the caliper?
If you've already removed the two screws that go through the rotor, theres nothing else holding it on, its likely just rusted to the hub. Try smacking it with a rubber mallet, or kick it with your shoed foot.
There should be anther spot where there were no screws but is threaded. But two screws in there and that should push it off the whatsamacall it.
Thats how it is on my sol. Good luck
Re: Front disc won't come off (nocternaldragon)
If the two X screws and caliper are off then just bang it in the middle a few times and it should pop right off.
Re: Front disc won't come off (EVIL Hx Coupe)
One of my buddys has a z3 and he couldnt get his off one time he called up a mechanic and he said sometimes water and crap might leak into it and cause it to rust and bond and they might as well be welded together. He advised him to secure his car super well (if in doubt dont do it) and lay under it and kick it as hard as he could. It took him about 5 min of kicking to get it off but it worked and no damage. This is probably not by the book but it works
Re: Front disc won't come off (hondadude96)
you can kick it or use a rubber mallet but if those dont work you can use a steel hammer on the center part of the rotor, the part that the pads dont ride on. this will break it loose. this happens all the time in lovely ny.
VTecLude1994
05-13-2011 08:11 AM
CBL9
07-26-2007 05:51 PM
