Front Brake GSR Converstion on a DelSol S
What parts do I need for a front brake swap on a delsol s. I m about to purchase front brake assembly including rotor,caliper and upper a arm for about $150. Is that a good deal. Parts have a estimate of 85,000 miles on it. Probably check out the parts tomorrow. Is there anything I should look for, condition wise? And what are the parts I need for the brake swap? Any help would be appreciated.
Re: Front Brake GSR Converstion on a DelSol S (vactor)
nope , he has those tiny 9.3 discs vs the gs-r 10.3 and larger calipers
and yes 150 is a good price but you need the teg spindles as well
Re: Front Brake GSR Converstion on a DelSol S (Doctor CorteZ)
what does the integra spindles look like. I'm about to go check out the parts pretty soon. thanks for the info.
Re: Front Brake GSR Converstion on a DelSol S (jrlude25)
just make sure the rotor is on the spindle and line up the caliper bolts , if its not a teg one they wont fit
kool, thanks. It should be a direct replacement. It shouldnt be that hard for the upgrade right?
Re: Front Brake GSR Converstion on a DelSol S (Plan B)
I have some more questions about brake swap and suspension. I would have to add the front lower control arm from a GSR in order to use the GSR swaybar right? And about the rear, I was also planning on using the GSR rear disk brake aswell. What parts would I need for the rear. I need the GSR rear control arm right? Can I use a integre type R rear control arm with the GSR brake assembly? All the help would be appreciated.
you don't have to use the rear lower control arm to do the disc swap. If you use the Type R rear lower you will need shocks that are made for the type R since it mounts differently. Email me if you have any questions.
RandomArchives
06-26-2017 12:20 PM
carid
03-25-2016 03:33 AM
