freak accident now won't start.
ok so i was driving my car and the driver side motor mount broke and the motor slammed on the ground!by this time i was pissed and deppressed. but i sat there and witrh the help of a friend and a ride i managed to pick up another motor mount and put it on and everything using factory honda jacks.so now when i got the car put together it wouldn't start. so i figured it was the battery.so we pushed started it. and everything was great car started no problem. i drove it around and decided to turn the key while i was driving to make sure everything was fine and nothing, starter doesn't grind or anything.the starter actuator is getting signal all wires are good. ignition is good. ground is good.if we push start it it runs. what could it be?? someone please help me out this is my daily driver and without this i'm stuck doing nothing.please help.also this is a 92 dx hatch with a 93 b17a1 gsr in it.running a cable GSr trannsmission.someone please help me.
H-T Poker champion
Re: freak accident now won't start. (tolowhb)
check and make sure the ground wire didnt rip in half or come off when the motor fell.. could be simple as that.
there should be the one that connects around the valve cover and another larger tranny ground..
Re: freak accident now won't start. (Hatchy-Ownzjo0)
where would the tranny ground be?yes the starter get signal and everything.power and everything is fine. when i turn the key to start all you here is a click coming from the under side of the dash.someone please help me!heh
yeah my friend had the same problem. his starter was loose. i think one of the terminals. not sure. but i just tightened the bolts all up and it starts like a champ ever since then.
Re: (H22BuiltEGhatch)
Yep defently the starter conections somewhere. Try taking them off and cleaing them up. I don't thing your oil pan bent in that hard so it woun't let you crank turn (stupid idea)
well i actually took off my starter and put it back on and it still won't work!someone please help i don't know what the hell to do!
Re: (happyabortion)
check the motor make sure nothing is really bent in or nothing is punched thru the block. Try to spin the motor with a wrench from the crank pulley. See if it's cranking.
Re: (ABK)
I think he said the motor runs so why would he need to see if it cranks over. If it is running shouldnt it be ok, I am not that smart but thats what it seems to me. He is just having problems getting it started. So probably nothing wrong with the motor, no holes in the block or anything.
Re: (ABK)
no it's not the motor. we push started the car to make it to my house and then again to make sure the car ran right.it has something to do with the wiring under the dash i believe.because everytime i try to turn it on some little module under the dash clicks.(also i chanmged this module out and no success). thans alot for the help you guysa any info or advice would be greatly apprecciated
Re: (happyabortion)
thank you all for so much help.what i ended up doing today in the morning earlier i ran a thick wire from the tranny to the negative post on the battery.tried it out and car started just fine.thanks everyone for there input.i really apprecciate the help
