Flow rate
Re: Flow rate (grenthang)
the heads are identical.. well b18b/b20b/b20z are identical heads.. the difference is the b20 cams are tiny bit more aggresive..differences are of couse intake manifolds
if you go with any non vtec b series setup.. I would forget the OEM manifolds and look to the Skunk2 manifold..overall it's best to at least use a ls intake manifold for fitment uses..I have seen b20z's torque chamber fit in a eg civic swap..
https://honda-tech.com/zerothread?id=508070
good lucks
good lucks
