Flip flop power locks! No idea what is causing it.
Soory to post in here but it wont let me start a post for 5 days. My son has a 1998 Civic and has power locks. When you lock the door on drivers side it unlocks passenger side. (Its a 2 door) when you unlock drivers side it locks passenger side I cant find anything on this. Any help would be great thanks.
Re: Flip flop power locks! No idea what is causing it.
Moved to your own thread. Definitely a worth while inquiry. Hopefully the pro's here can help you out.
I'm not an electrical genius so sadly, I'm not of great assistance other than letting you have your own thread early.
Best of luck.
Best of luck.
- What trim level is this Civic?
- Are the door locks OEM?
- Does the car have keyless entry (via remote)?
check to see if there are any signs of repaired wires on the locking switches. Then I would use a schematic to check wire colors to the door locks i.e. locked and unlocked circuits sure sounds like a polarity issue You are locking from the master switch on the driver side I presume.
sounds logical, 1st Using schematic I would check to see when what wire is hot in what position (like lock)and what wire is ground at that position and then in the opposite (unlocked)since polarity changes depending on switch position.I would check at the switch on the passenger side and then at the master side. see if that checks out.
If the car was bought like this, it could be either due to
- incorrect wiring by previous owner or
- the use of an aftermarket door lock actuator with the motor wires already incorrectly inserted in the connector (essentially switch around).
Oh look, I can change this
Hauki816
01-19-2013 09:29 AM
XanderusMaximus
12-19-2011 08:46 PM
all stock
01-15-2005 12:49 AM
Jay J
Audio / Security / Video
11-26-2003 02:37 PM
