96 Civic moonroof / sunroof rattle
Old 03-14-2009, 11:02 AM
SteveInOakland's Avatar
Default 96 Civic moonroof / sunroof rattle
Have seen this described here a few times but not much in the way of fixing it.
It's intermittent, but if you hit any kind of bump or even wavy road, it happens c. 40% of the time. It's a chatter, like some medium-sized part slapping against the sheet metal. I guess if you took off the headliner, you'd see whatever is wrong pretty quickly....
The rattle will sometimes stop if you open the roof. And you can usually stop it by pushing your hand up against the rear middle of the ceiling.
Question -- towards rear of ceiling, in center, there's a plug that pulls out and a brass nut underneath -- 12 mm IIRC. The nut seems to be an adjustment thing, can tighten or loosen. Not just a fixing bolt (or why wouldn't they just permanently cover it).
What is that nut??? And any other tips on the rattle?
Many thanks.
Old 03-14-2009, 03:25 PM
Default Re: 96 Civic moonroof / sunroof rattle
Just to clarify -- the sunroof doesn't rattle. The rails/mechanism up under the headliner, behind the roof opening, rattles.
Thx.
Old 03-14-2009, 03:29 PM
HRD PKR
B16B_coupe's Avatar
Is this 100% a rattle and not a squeak?
Old 03-14-2009, 03:49 PM
Yes -- not a squeak at all. Just a rattle, or chatter. Usually a rapid one, i.e. a bunch of clicks/knocks in fast succession.
Thanks for your interest.
Steve.
Old 03-14-2009, 03:58 PM
HRD PKR
B16B_coupe's Avatar
I see... i would take a blow gun and try to blow out any debree that could be up in around the sunroof area
Old 03-15-2009, 03:19 AM
H-T White Ops
NOFX's Avatar
Many thanks.
I have this exact same problem and haven't figured it out yet. I replaced the sunshade and glass and tightened it all back up and it still does it whenever. The sunshade can be opened or closed and the glass can be opened or close.
There is a TSB for a squeak that involves putting in tape around the hole in the roof so the seal doesn't squeak against it, but that's not my issue.
The plug on the roof... if your moonroof gets stuck open then you remove the plastic plug and use an allen wrench (or moonroof tool) to close the moonroof though that hole in the ceiling.
Old 03-15-2009, 10:42 AM
Appreciate that, NOFX! Very glad to know what that plug on the roof is. (Maybe it's even described in, er, the owner's manual...)
Please post if you get this figured out. Maybe even in this thread?
Steve.
Old 03-15-2009, 03:59 PM
H-T White Ops
NOFX's Avatar
I'll try to remember to post here if I figure it out.
I've been trying to get it on and off for over a year though.
HubeyHatch_EK
10
12-18-2007 10:33 PM
xXSilentScreamXx
08-03-2007 04:44 PM
Seanith
09-05-2005 10:12 PM
SyDuck
06-01-2005 10:43 PM
themanhasskillz
09-03-2001 06:29 AM
Quick Reply: 96 Civic moonroof / sunroof rattle
